Question about LG Washing Machines
Lg problem Direct drive model F10A5QDP-7Kg; front loader 2012 Problem: machine can sometimes not be opened after washing.Long waiting before opening or switching off power does not help. Wim Koppenberg
    New Friend:
    Problem Solver:
  • 15 Answers
Problem with door switch bi metal,,,kindly replace door swich,
Posted on Apr 23, 2014
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
SOURCE: Please help! My samsung 7kg J845 front loader
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Posted on Oct 25, 2009
SOURCE: LG Front Loader Washing machine: WD8013F
when we press wash,does not start. all light start flashing after 30 seconds.
Posted on Aug 18, 2011
Have a lg direct drive front loader model wd11020d makes a knocking noise and after a while an Le error comes up, pulled the back of all looks in good condition
Open front door. Pull push on inner drum and see if it wiggles independent of outer drum. If it does, then the knocking is a bad bearing or spyder(part that hold drum to bearings). If inner tub is tight, then I'm not sure issue. LE error is a Rotor Position Sensor error.
Jan 30, 2017 | LG Washing Machines
I need an Operating manual for LG 7kg Direct drive automatic washing machine please
They are freely available from look in support, you will need the model number off the detergent drawer.
Apr 19, 2010 | Washing Machines
How do you change the front door seal on a LG 7kg front loader washing machine
Well I have the manual. If you want it.If the problem is water leaking out the door LG recommends you shim the door latch with washers. This would make the door close tighter and eliminate leaks. See page 36
Mar 12, 2010 | LG Washing Machines
7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Jul 14, 2008 | Washing Machines
Washing Machines Logo
201 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
