Question about FXLAB 30 mW Pulse 1 Green Laser System with 50 Patterns G018EA
Laser is fuzzy not crisp
Compared to another unit I own the beam is fuzzy and not defined. A sharp tap sometimes helps improve.
My coloured copy machine sharp mx 2300n is showing error code e7-20 please How do i fix it.
E7-20 is problem with laser unit - Black. Check connectors, optical axis of laser beam (in case there were assembly / disassembly actions). Laser unit can be defective.
Sep 02, 2016 | Sharp MX-2300N Color Copier
One side of the printed side comes out feint compared to the other side of the sheet.
It is most likely be due to dust accumulation at the laser reflecting mirrors inside the copier, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Sharp AR-5320 Black and White Copier
It seems to be fuzzy ,cant focus it sharp and crisp
You are using too much magnification. Put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x barlow if you have one. Practice focusing on a distant object during the day time..
Read my tips on my profile page.
Jun 20, 2010 | Galileo (DB160) Telescope
Epson Stylus NX300. I send a FAX and the folks on
check first if your printer can copy well. try to photocopy a document. and if it copies well, that means, its a problem on the part of the receiever, if it does not copy well, that means the scanner of your unit has a problem.
Feb 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
D70 photos not sharp - no matter which lens I use.
D70 produces lovely crisp images as long as the lens is pretty good.  This sounds like a camera body that needs a service.,,
Apr 19, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
I get a partial copy when using my Sharp FO 5600
Make a copies with something with a lot of print. open top cover when the paper is 1/2 way through the machine. pull out the toner & drum unit's look at the drum is there a full image on the drum but not on the paper then it is a transfer problum. If no image on the drum then we have a laser unit problum. There is a shutter that opens when you put the drum in & closes the top cover. it may fallin out of place. hard to git at or somthing is blocking the laser beam ( paper, dust bunnyies or fourn objest ) hope this helps let me Know
C.W.H.
Jan 29, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Flesh tones and red colors
any hue adjustments usally relly cheap tv u got also hard to get good colers from it the lg one is nice i like samsung and sharp
go throw azll colers cheak dvd cables
Jan 06, 2008 | Insignia IS-LCDTV32 32 in. Television
Sony DCR-PC330 Indoor Performance
Hi, The traditional measure of image sharpness is stated in line pairs per millimeter ? abbreviated as lp/mm. In other words the ability of the human eye to discerned the number of high-contrast pairs of lines appearing in the space of a single millimeter. It may help you to get a better result. Daniel
Sep 13, 2005 | Sony Handycam DCR-PC330 Mini DV Digital...
FXLAB 30 mW Pulse 1 Green Laser System with 50 Patterns G018EA Logo
464 people viewed this question
Top FXLAB Electronics - Others Experts
Are you a FXLAB Electronics - Other Expert? Answer questions, earn points and help others
