Question about FXLAB 30 mW Pulse 1 Green Laser System with 50 Patterns G018EA
Laser beam fuzzy not sharp. - FXLAB 30 mW Pulse 1 Green Laser System with 50 Patterns G018EA
My coloured copy machine sharp mx 2300n is showing error code e7-20 please How do i fix it.
E7-20 is problem with laser unit - Black. Check connectors, optical axis of laser beam (in case there were assembly / disassembly actions). Laser unit can be defective.
Sep 02, 2016 | Sharp MX-2300N Color Copier
What means E7-20 error code for sharp mx-m850
The code refers to the laser beam detection in the laser assembly.
The first thing to do is completely power the machine off & then back on to see if the machine resets. If it doesn't reset then the fault lies with the laser assembly itself & would require a technician to strip the machine to locate the problem.
Dave.
Jan 20, 2016 | Sharp Office Equipment & Supplies
Pacific Laser Systems PLS5. Are the left and right beams supposed to be at right angles to the down beam? I took another laser chalk line focused the PLS down dot on the chalk line beam. The left and...
one of the problems with this type of equipment is the fact that the down beam has to be set to a true plumb position. If it is possible to swing the head without disturbing the mounting you can check for circling - motion of the down beam in a circular pattern - which indicates off plumb placement.
Dec 22, 2017 | Pacific Laser Systems PLS5 Automatic Laser...
One side of the printed side comes out feint compared to the other side of the sheet.
It is most likely be due to dust accumulation at the laser reflecting mirrors inside the copier, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Sharp AR-5320 Black and White Copier
What does E7 error means?
That is normally a problem with the laser. I would think what is called the polygon motor has failed. That is the motor that spins the mirrors in the laser.
You can replace the motor or the laser. It is possible that the laser is not putting out a beam . But most of the time that motor fails.
Aug 09, 2010 | Sharp AR-168D Copier
Blurry print on Minolta Bizhub C350
CLEAN LASER UNIT ON THE DOOR U HAVE STICK AND PADS FOR CLEANING
Apr 09, 2009 | Konica Minolta Office Equipment & Supplies
I get a partial copy when using my Sharp FO 5600
Make a copies with something with a lot of print. open top cover when the paper is 1/2 way through the machine. pull out the toner & drum unit's look at the drum is there a full image on the drum but not on the paper then it is a transfer problum. If no image on the drum then we have a laser unit problum. There is a shutter that opens when you put the drum in & closes the top cover. it may fallin out of place. hard to git at or somthing is blocking the laser beam ( paper, dust bunnyies or fourn objest ) hope this helps let me Know
C.W.H.
Jan 29, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
FXLAB 30 mW Pulse 1 Green Laser System with 50 Patterns G018EA Logo
414 people viewed this question
Top FXLAB Electronics - Others Experts
Are you a FXLAB Electronics - Other Expert? Answer questions, earn points and help others
