Question about Honeywell Home Security
Ftp dlink com
Fire Panel DEltaNet FS90
Dap-1522 setup wizard
You can download the latest version of the firmware you need below. Just determine if you have dap-1522 or dap-1522 rev.B.
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. Example picture on the bottom of this page.
latest dap-1522 firmware:
ftp://ftp.dlink.com/Multimedia/dap1522/Firmware/dap1522_firmware_141b.bin
latest dap-1522 revB firmware:
ftp://ftp.dlink.com/Wireless/dap1522_revB/Firmware/dap1522_revB_FW_203b.bin
Install instructions for the firmware are on page 41 in this pdf:
ftp://ftp.dlink.com/Multimedia/dap1522/Manual/dap1522_manual_130.zip
Here is a great setup video for it:
http://www.youtube.com/watch?v=lYJPGqtyFZU
Jun 05, 2012 | Computers & Internet
DAP-1522 WIZARD
The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. See the example picture on the bottom of this page.
I can not get the wireless settings to work
I have a dlink and i love it. did you go into your settings correctly? try going into your brower and type in your ip address. most likely it will be 192.168.0.1 and then hit enter. it will take you to the settings. if you did not set any passwords or anything then just click on log in. click on internet set up connection wizard and it will guide you step by step through everything and if there is a save button remember to hit that. Also I would go under the tools tab and then click on firmware and see if there is an update for it.
Mar 01, 2011 | D-Link DIR-615 Wireless Router
I need an install disk for my usb wireless adapter. I lost my disk.
OK... Just download the driver/software revision matching your USB adapter (have a look on it's sticker. If no revision is noted, then it's simply DWA-130!):
DWA-130:
ftp://ftp.dlink.com/Wireless/dwa130/Drivers/dwa130_drivers_130.zip
DWA-130_revB:
ftp://ftp.dlink.com/Wireless/dwa130_revB/Drivers/dwa130_revB_drivers_200.zip
DWA-130_revD:
ftp://ftp.dlink.com/Wireless/dwa130_revD/Drivers/dwa130_revD_drivers_100.zip
DWA-130_revE:
ftp://ftp.dlink.com/Wireless/dwa130_revE/Drivers/dwa130_revE_drivers_510.zip
I assumed you're using a Windows OS...
Mar 13, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
Installation software
Try this link you can find drivers + Software
Added WPA Support, Supplicant is built-in to drivers.
ftp://ftp.dlink.com/Wireless/dwlag650/Driver/dwlag650_driver_237.zip
or
ftp://ftp.dlink.com/Wireless/dwlag650/Driver/dwlag650_driver_235.zip
Hope this will solve your problem..
Nov 22, 2007 | D-Link Air DWL 650 802.11b Wireless...
Home Security Logo
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
