Question about Dehumidifiers
Car keeps cutting out
I have a ford galaxy 1.9tdi it keeps cutting out whilst driving
  • Dehumidifiers Master
  • 3,382 Answers
I assume you are talking about the AC compressor. Low gas or low evaporator temperature will cause it to cut out, If it is blowing relative warm air it is low on gas.
Posted on Apr 30, 2014
The bucket keeps filling when the drain hose is hooked. What can i do to make itdrain out the hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 15, 2017 | Dehumidifiers
Keeps running compressor
Hey randall, thank you for your post!
I see that you're stating the compressor continues to run on your Frigidaire dehumidifier. What you could be hearing is the fan running. The fan will run when the compressor cuts off so that air can pass over the sensor coils to check the humidity. Hopefully this is helpful. -Matt
Sep 12, 2014 | Frigidaire Dehumidifiers
Ford galaxy 1.9tdi keeps cutting out then starts no problem must be something turning pump off lots of people have same proplem but not telling what fixs it
Crankshaft sensor can cause this kind of behaviour does it have the tandem pump on it as these are the best ones to have been put on these engines failing the crank sensor there is a relay under the dash in the fuse box somewhere that also causes this behaviour although I'm not actually sure this happens on the diesel pd engine best to check on the ford forums
May 07, 2014 | Dehumidifiers
I have cable comming in to my 2 tv's no box the video is fine but the audio keeps cutting in and out! Any ideas?
There is a method of "scrambling" signals that will cause that unless you have there cable box. It sounds like that is the problem.
Apr 15, 2014 | Dehumidifiers
Is it better to have windows closed or open whilst operating a dehumidifier?
think about it. If you are trying to dehumidfy a specific area, then opening windows just lets in more humidity that your dehumidify must take care of.
Jan 22, 2011 | Dehumidifiers
DEHUMIDIFIER IS NOT TAKEN OUT ANY MOISTURE IT KEEPS CUTTING IN AND OUT
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Dec 28, 2010 | Danby DDR3009EE Dehumidifier
My Goldstar Dehumidifier keeps cutting off even though its not full of water...any help?
A few things you could try are to make sure the float isn't covered in gunk and moving sticky-like, make sure air filters are clean and the compressor isn't overheating, and make sure the humidistat (probably a knob that says drier with arrows) isn't turning the machine off because it's reached the set level.
Nov 25, 2009 | Goldstar Dehumidifiers
My dehumidifier keeps cutting out.
Most likely..motor cycles on over load switch..
Nov 04, 2009 | Dehumidifiers
Dehumidifiers Logo
57 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
