Question about Ovens
Haier pad ct1010w
Haier pad is charging but it is not starting
I have p5h code on a whirlpool oven model yxfe36lvb can't find anything on it
The START pad begins any oven function. if the START pad is not pressed within 5 seconds after pressing a function pad, the Push to Start ["PSH"] indicator light will flash and the push to start tone will sound as a reminder. you can download a manual for your range at go to "owner center", scroll down to "manuals & literature" and enter your model number
Oct 01, 2016 | Whirlpool Ovens
Manuals
consult a technecian
Apr 26, 2013 | Ovens
Oven will not turn on
check temp control. then select timer
Mar 31, 2013 | Haier RTC1700SS Electric Single Oven
Haier RTC1700ss digital display doesn't work. Beeps when plugging in but no functions
Hello
Here are a few things you shoul look at and try to correct to make your oven work properly
Make sure the electric oven is plugged in properly.
Check that door closes completely and its latch is aligned.
Check that interlock switch in door works properly (required for activating oven).
There might be a blown fuse,replace blown fuse if it's accessible, or contact a service technician.
Inspect plastic coupling beneath tray.
Check ring and roller assembly for misalignment or debris.
Make sure that tray is sitting properly on turning mechanism.
If carousel motor is broken, contact a service technician
Make sure there's no aluminum foil or metal trim on dishware.
Food residue or burned spots can cause electrical arcing. Clean chamber thoroughly. Replace wave-guide cover if burned or carbonized.
Sand away burn spots, and smooth rough metal edges.
Touch up spots with microwave interior paint if necessary.
If chamber has burn holes, contact a service technician.
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Jun 20, 2011 | Haier RTC1700SS Electric Single Oven
I have Haier Hr-18G microwave oven I don't know how to operate it
Jan 25, 2011 | Ovens
Eurolec stove auto ignition not working
press for few sec for hold and ignate the knob
Dec 09, 2010 | Haier Ovens
HOW TO ADJUST THE OVEN THERMOSTAT ON A WHIRLPOOL GAS OVEN MODEL SF387PEYQ7. THANKS AJ
Press and hold BAKE pad for five (5) seconds. Current offset, if any is shown in 3-digit display. CAL is shown in 4-digit display (3 digits on right).
Pressing the UP pad adjust the temperature in 10 degree F increments in fthe following sequence: 0, 10,20,30,-30,-20,-10, 0 and so on.
Press START/ENTER pad to activate the desire tempature adjustment. If the START/ENTER pad is not pressed within 5 minutes, adjustment is ignored.
May 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven only works at max temp
The oven temp switch should be replaced.
This switch has a long tube which goes from the switch to the inside of the oven. The switch can be replace without much of a problem but, feeding the new tube down to the oven can be tricky sometimes. The old tube will come out but you have to find the same hole to put the new tube back through, sometimes this will go through insulation and you can't see the hole where the old tube came out. It's not hard to do just be aware of this problem.
Dec 16, 2008 | Ovens
GE JKP27WP1 Built-In Double oven - the start button on the touch pad doesn't work. Everything else works fine. Haven't received an error code.
Try gaining access to the touch pad and, try to free up the start button. if this is unsuccessful, replace the touch pad.
Dec 16, 2008 | GE JKP27 Electric Double Oven
Ovens Logo
93 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
