Question about Android Apps
Installing a memory card.
OK... I bought a new memory card for my pendo pad but I still can't download any thing or take photos. I have no music or pictures and I have one game so I bought a new memory card and still can't do anything. What do I do?
  • 3 Answers
SOURCE: Memory Card Locked
There is an option to lock the memory card, so here's what you do. Open battery slot<remove card<there is a lock tab just switch it to unlock. tab is on side of card on SD card
Posted on Dec 26, 2007
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Posted on Sep 11, 2008
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Posted on Dec 24, 2008
SOURCE: I cannot connect my LG secret to my PC - only the music side not the photos
will sum1 help me
Posted on Jul 03, 2009
  • 272 Answers
SOURCE: 8gb memory card corrupted.
If its cost a lot, it should have warranty. Go and ask for a replace. 7.63 GB is ok for a 8 GB card. cz, file system itself takes some space.
But i dont think the card is still good.
Posted on Oct 09, 2009
How to reset a pendo pad when its not on
Bear in mind that this restores to factory defaults. In short, it is like you went out and bought a new one and just opened the box.
Pendo Pad Factory Reset Hard Reset Remove Pendo Pad Password Passkey
Oct 11, 2017 | Cars & Trucks
My LG VX 8550 phone was not working properly so i brouth it into the Verizon store and they replaced it with a new one. My music is downloaded on the memeory card which was placed in th enew phone which is...
may be files in the memory card are corrupted or the software which is needed to play the format is not installed ...
if that software is installed then there may be some firmware problem ....
try giving the restore factory settings once if there is any firmware problem it will be solved
Jul 01, 2008 | Cell Phones
What does a pendo pad charger look like ,
Hi if u check E,/BAY U CAN c A PHOTO THERE just type in there seach pendo pad charger. good luck
Mar 07, 2016 | Tablets & eReaders
My pendo pad keeps saying insufficient storage when trying to download apps.
Go into the settings and look for 'Storage'. In there you will find an 'Apps' heading, open it up and then tap on each app that is there and look for a 'move to SD card' option.
Jan 18, 2016 | Cameras
G'day. I can not access my pendo pad I have forgotten my password. I am locked out of it. How can I get into my pendo pad.
Craig, jump onto YouTube and search on "Pendo Pad Reset" for ideas. Lot's of good stuff out there and standard reset steps for Android devices are covered.
Jan 29, 2015 | Computers & Internet
On my pendo pad THE process android.process.acore has stopped working
Hi you will probaslly have to flash the pendo pad, its not too hard to do here are my instructions, - unfortunatly a pendo pad does not have a recovery menu to access on device boot
note - this solution also unlock the pendo pad and restores it to factory settings even if it wont boot the android os
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back to the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Dec 20, 2012 | Cell Phones
How to recover pictures from sony cybershot
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this photo recovery software called asoftech photo recovery
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Apr 06, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Need to recover deleted photos. Accidentally deleted photos on camera but somehow did not download to computer any way to recover from memory card?
Download this camera photo recovery software
May 15, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
How to recover my deleted photos?
you can recover deleted photos with photo recovery software like asoftech photo recovery, download from
Download Photo Recovery Software
Please be noted that your camera memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Nov 17, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
I bought a new memory card when i plug my phone into pc to download music or photos the memory card does not show up
check the connection cable or try using another cable then check the phone setting that is connectivity and try.
Oct 16, 2009 | SanDisk 2GB microSD Memory Card
Android Apps Logo
73 people viewed this question
Top Apps Experts
Brett Duxbury
Brett Duxbury
Are you an App Expert? Answer questions, earn points and help others
