I have the same problem offfff
I hope i can find the solution here
  • 1 more comment
  • Nelson Olaso
    Nelson Olaso May 11, 2010
    what kind solution you need it?
  • Alun Cox May 11, 2010
    Ditto
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Because of heavy traffic on this site we do not know what your problem is !!!! by saying you have the same problem does not give us any idea of what the problem pertains to, you need to explain exactly what your problem is for us to be able to help you.
    Regards
I have a 1989 Oldsmobile cutlass ciera v6, 62,000miles...two months ago had a whole new muffler system put on it and a new alternator. about 2 weeks ago I knows my idle was going up and down like someone...
The next step after inspecting for leaky vacuum hoses, etc. is to read out the engine error code(s). The instructions at the following link explain a simple means to do it (your car most likely is one of those covered; make sure your diagnostic connector matches the shape and number of connections shown to be sure).
FAQ How to read older GM codes for free
One clarification on the page: when the author writes " Ground terminals A and B" in step 1, that means connecting terminal A (Ground) to terminal B (Diagnostic enable). The easiest means to do so is to bend a paper clip into a U-shape so one leg of the U goes into the A pocket of the connector and the other goes into the B pocket. You can also use the points of a needle-nose pliers, but the paper clip is more convenient. Be very careful not to connect any other terminals together, and don't forget to remove the paper clip before trying to run the engine. (When I had a 1988 Buick, I kept a U-shaped paper clip in the glove compartment just for this use.)
Once you know what the error code means (there's a link on the page to a table, you'll have a general idea of where to look for the problem. If you want to know more about what the code indicates, please provide the information in the comments or post your question again with the error code (sometimes the same code is caused by one several different parts, each of which is too expensive to replace on a "this might be it" basis).
Read more at: https://www.obd-codes.com/faq/read-gm-2-digit-obd-codes-free.php
Copyright OBD-Codes.com
Sep 16, 2017 | Oldsmobile Cars & Trucks
I took a radio from one 2000 sunfire and put it in another. The LOC is on and will not work. How do I reset the code?
You need the code for the radio first off and i hope you have it. If you do, I gave you the procedure for the 1999 sunfire but am 99 percent sure it's the same as the 2000. I hope it is and I hope you have the code. I hope this helps and good luck.
May 01, 2011 | 2000 Pontiac Sunfire
The transmission of my 1998 honda acord stayed in parking
try pluggin offfff the battery!!! and let it off for 10 minutes. and then`plug it again.
hope that helps
cheers
Jun 13, 2010 | 1998 Honda Accord
Printer will not wake from sleep mode to print
switch offfff,,, remove the plug ... plug it again ,,, restart pc ,,, switch it on.................hope it works
May 27, 2010 | HP LaserJet P3005n Printer
Can't locate my fuse box for my headlights was hoping it's not under the passenger side panal.
Yes if there was any place to hope it's not.....it's under the passenger side panel.
Why hope it's anywhere, or not anywhere. just look on line and google the answer.
Jan 03, 2010 | 1991 Buick Park Avenue
Lg dryer not drying dle0332w.
I would check the heating element. Hope this helps. You can take the back off but make sure it is unplugged... The heating element is in the tube long box. Hope this helps. Heating elements are easy and cheap repairs. Hope this is what is wrong.
Dec 10, 2009 | Dryers
Hi everyone. Hopefully an easy question. What
If memory serves me correctly, I believe the dome light fuse controls the trunk light.
I hope I'm right! :)
Sep 14, 2009 | 1987 Chevrolet Nova
I am not able to find my manual. I am hoping that
Try going to Google, put in brand,model and your request. Has worked for me. You may have to try several sites.
Jun 22, 2009 | Audiovox Radio Communications
Ipod touch can not boot.It show apple logo
Hope u have back-up...Do a reset..soft one ....
hope it helps...keep the hope:)
May 20, 2009 | Apple iPod nano
Computers & Internet Logo
Alun Cox
David Payne
David Payne
