Question about Hobart Dishwashers
Bof fault code - Hobart Dishwashers
  • Hobart Master
  • 3,247 Answers
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
http://www.dishwashers-direct.com/uploads/Operating%20instructions/Hobart/AMX%20RANGE%20OP%20MANUAL.pdf
Posted on Apr 19, 2014
Good morning we got a Hobart dish washer turned it on code says bof
Needs a boiler fill sequence carried out. Will tell you how in the manual
Nov 08, 2017 | Hobart Dishwashers
Either BOF or EOF is True
The BOF property returns True (-1) if the current record position is before the first record in the Recordset, otherwise it returns False (0).
The EOF property returns True (-1) if the current record position is after the last record in the Recordset, otherwise it returns False (0).
Jan 11, 2014 | Computers & Internet
When printing a label on brother QL-1050 printer comes up with error "Either BOF or EOF is true or the current record has been deleted Requested operation requires a current record" I have removed...
I solved this problem by pressing "Control N" to bring up a new label. Works fine that way.
This is the answer Brother gave when I called them:
Description of Problem 100000003722
When I click print I receive the error message: Either BOF or EOF is true, or the current record has been deleted.
Description of Solution 200000004488
This error message occurs when you print a label that has no record in the database table.
To avoid this error message, click on Database menu, select Create New Record.
Oct 09, 2010 | Brother QL-1050 Label Printer
Bof error hobart amx
Sorry so late for the reply.Im a hobart tech and i dont recall this model of your unit,are you sure the model isnt a am-14 or am-15?
Aug 16, 2008 | Dishwashers
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
Hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Mar 13, 2008 | Dishwashers
Hobart dishwaser
hi,i just read your issue.im a hobart service tech and fix these units all the time.what model do you have and are you sure the error is bof?let me know,i can tell you all the info,error codes about hobart dishwashers.
Jan 14, 2008 | Dishwashers
Dishwashers Logo
288 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
