Question about Breville Toaster Ovens
The grill not working can buy the element ?
Breville mini oven oronto bov500
2 Suggested Answers
beltronic205
  • 1460 Answers
SOURCE: Cant remove warped top grill element
normally this is quite simple 2 screws hold the element on ..If its warped the you could cut it out with a junior hacksaw....Try not to breath in the dust from same...
Posted on Mar 31, 2010
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
Mar 04, 2016 | Breville The Smart Oven Convection Toaster...
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
The Breville BOV650XL will not power on.
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Feb 25, 2012 | Breville BOV650XL 1800 Watts Toaster Oven...
I need an operating manual for the Breville convection toaster oven
Hi there.
You will be able to find Owner's Manual of Breville Convection Oven at http://www.breville.com.au
Regards.
Jul 11, 2011 | Breville Toaster Ovens
Mar 31, 2010 | Toaster Ovens
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
Can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
Jun 16, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Toaster Ovens Logo
29 people viewed this question
Top Breville Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
