Question about Garden
Suffolk punch 43 sk
What voltage is a battery on a qualcast 43 sk
  • 3 Answers
SOURCE: maintenace Manual for Suffolk Punch petrol-driven Lawnmower
Have you checked with the company that makes the mower for the manual? Hae you tried searching the internet to see if you find the manual there?
Posted on Dec 09, 2008
  • 16 Answers
SOURCE: Please advise on where to puchase replacement
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Posted on Aug 31, 2009
  • 110 Answers
SOURCE: My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Posted on Sep 24, 2009
  • 110 Answers
SOURCE: i cannot start my Suffolk punch 43s petrol mower,
As far as I can tell, there are no downloads available. I eventually gave up and bought a copy from a mower museum. You will need to know the approximate age, as several diferrent engines have been fitted.
If you have the old red engine, the choke lever should be at right angles to the line of the carb IE pointing straight back.
The newer green engines are usually marked, but of not, remove the air filter and look into the carb throat. When the choke flap is CLOSED, the choke is ON IE cold start position.
As soon as the engie starts, move the choke to approx 50%, then fully open after 30 seconds or so.
If in good order, these engines are a 1-pull start. Fit a new plug, then spray WD-40 or similar into the OPEN carb thoat. If there is no sign of life at all, you have a coil failure (or possibly a points problem if it's ancient).
Posted on Oct 03, 2009
bobthebulldo
  • 67 Answers
SOURCE: Qualcast Suffolk Punchbowl will not start, have
it sounds as if the air filter is choking the engine take air filter off and see if the same happens, other than that it could either be plug needs changing
Posted on Oct 17, 2009
I need a carburettor to fit my qualcast Suffolk punch 35S 004928A
hi rebecca.
i have had a look on the internet but can not find out where you would get one,you could try phoning the main dealers or try ebay.
Nov 17, 2017 | Garden
Ihave just purchased a qualcast suffolk punch 30s the question l have, how do l check the engine oil level, l know were to fill the engine oil.Regards.Brian Bromley
Take the oil cap off with a flash light look in. take a stick or something small enough to put in the hole it shouldn't go all the way down. Where it stops that is where the oil level should be if you can't see any oil there thin add oil just to that mark. DO NOT OVER FILL .
Aug 02, 2016 | Garden
My Suffolk punch 17 sk will not start
Check for spark at plug.
check for fuel getting to the plug.
Lastly check compression.
Oct 12, 2014 | Garden
Where can I get a Manual for my Suffolk Punch Petrol Mower 17SK
Hi anon the easiest place would be QUALCAST direct.
Aug 11, 2014 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
I have a new suffolk punch 17 sk but i am not getting a good cut it looks like its missingparts of the grass
Suffolks are designed for short grass,might u abrade this on a gauze area..use this with a care and soft hand.do regualar maintance surely advance Suffolks machine life.
May 31, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Can't remember how to keep my Qualcast Suffolk running!
There is a video on u tube and a wed site the old lawnmowers club .
Jan 10, 2018 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Aug 30, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
