Question about Neff Refrigerators
Neff fridge freezer not working, interior light flashing and temp lights if come on soon go off , fridge and freezer not working
  • 210 Answers
SOURCE: Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
Posted on Jun 07, 2008
  • 93 Answers
SOURCE: GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Posted on Jul 17, 2008
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
Sea Breeze
  • 4654 Answers
SOURCE: My Samsung RL39WBMS fridge is not working. The
The best answer I can give you is because you are in UK please click Here=> Samsung UK Thanks, Sea Breeze
Posted on Mar 25, 2010
imufo2
  • 3773 Answers
SOURCE: Fridge freezer has suddenly stopped working temp
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 26, 2011
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Green light does not come on for settings 0 to 4
the ice cream is the clue,if it goes hard then the temp is too low (ice cream best kept at -18C)
either the defrost is not working or interior temp sensor duff.
Mar 26, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge/freezer temp lights and interior light dont work
I found a repair diagram on the web that showed the parts picture and part number and saw the box in the back lower left corner of the refrigerator that housed the circuit board.
Jun 18, 2008 | Whirlpool GS6SHAXMQ Side by Side...
Refrigerators Logo
26 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
