Question about Panasonic SA-HE90 Receiver
Cooling fan is not running and sound cuts out when receiver heats up
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
How about replacing the fan???
Posted on Mar 18, 2016
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
I have a 2013 Brisk air 1500 ducted A/C. The problem is after several hours of cooling the fan will shut off but the compressor will continue to run (humming) After shutting of unit at thermostat and
sounds like the fan over heat, you may want to check the fan relay and wiring for corrossion and capacitor as it may not be shorted but lower in value and making the fan over heat and triggering its build in safety cut off..
Jan 06, 2015 | Brisk Air Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
4 ton Amana -heat comes on sporadic in spring and fall (Every season change) Heat worked through 20 degree weather. Thermostat at 74. Today is 100% humidity and 52 degrees outside and heat won't work. By...
Assuming this is a heat pump I'm guessing you have a bad temp sensor. Your outdoor fan is likely controlled by a temp sensor so it only runs as needed during heating. Fan not coming on and compressor still needs cooled therefore compressor protection kicking in?????
Aug 12, 2017 | Amana Heating & Cooling
Sime ecomfort plus 30 HE keeps cutting out and shows a flashing green light. Sometimes it will run ok for a couple of hours before cutting out.
I had the identical problem with the same model. Technician eventually diagnosed faulty fan; the fan cools the heat exchanger. When fan fails, exchanger overheats and boiler automatically shuts down. It is possible to restart the boiler when it cools down but when the heat rises again - off it goes! Only answer is to replace the fan. My technician did the same as yours - on first visit he got the boiler running and left. Half hour later, boiler shut down. I read the installation manual and operating instructions and when he called again I pointed him in direction of fan, which had failed completely. These guys!
Apr 11, 2012 | Televison & Video
Electric fan wont kick in jeep over heats replaced thermostat and two sender units
Sounds like your cooling fan relay is bad the jeep grand cherokees are known for this, first thing i would do is unplug the radiator cooling fan and run 2 jumper wires direct from the battery to the fan connector if the fan kicks on your fan motor is good and the relay is bad, if the fan doesnt kick on replace the fan motor with a new unit, the cooling fan relay on your particular model jeep is located under the passenger headlight and requires you remove the front bumper to replace it, however some people cut a small hole under the headlight to access the relay the faster way but if your not to keen on cutting holes in your car remove the bumper and replace the relay if the fan checks out and you wont be overheating anymore...
Dec 07, 2010 | 1999 Jeep Grand Cherokee
2001 Neon cutting out, but only in the heat of the day
SOUND LIKE ENGINE RUNNING HOT.MAKE SURE COOLING FAN TURNING ON. WHILE ENGINE IDLING WATCH TEMP GAUGE AS THE TEMP CLIMB COOLING FAN SUPPOSE TO TURN ON IF NOT.CHECK FAN FUSE AND RELAY. IF BOTH GOOD HOT WIRE IT. NO RUN REPLACE FAN MOTOR IF FAN MOTOR DO RUN. YOU COULD HAVE A FAULTY COOLANT TEMPERATURE SENSOR OR SHORT IN FAN CONNECTOR OR WIRES. CHECK COOLANT LEVEL.MAKE SURE YOU HAVE 50/50 MIXTURE OF WATER AND ANTIFREEZE.TO BE ON SAFE SIDE REPLACE THERMOSTAT AND PRESSURE CAP.
May 30, 2010 | 2001 Dodge Neon
Tv cuts off and on no picture or sound
Most TV shut downs like this are HEAT related.Try increased cooling with a fan blowing into it to test this on yours.If it works leave the fan running or repair with a nice little but strong computer fan placed behind the unit..
Aug 17, 2009 | LG 32LG30 32 in. LCD HDTV
Cooling fan in reciever noise.
Its necessary to run cooling fan because Amplifiers in home theater system produce heat during its operation. If you shut down cooling fan, Amplifier ICs may be damaged due to over heat.
Aug 24, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Panasonic SA-HE90 Receiver Logo
107 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
