Question about LG Audio Players & Recorders
Lg mdd62 only demo is displaying - LG Audio Players & Recorders
How do i remove the 4 boxes that keep coming up at the lower left of the screen?
  1. go to main menu -
  2. select display -
  3. select advanced at the bottom of this screen -
  4. in this menu you can turn on/off the trumotion demo.
May 22, 2016 | LG 42LG50 42 in. LCD HDTV
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
How do i take my television out of demo mode
It is a setting that can be turned off by menu selection [in home use] or [auto demo off] depends which model year as to what it displays.
Oct 13, 2014 | LG Televison & Video
Can't get out of demo mode
On most, if not all similarly styled refrigerators, demo mode is toggled off and on by holding a combination of buttons on opposite sides of the display. Which buttons can depend on manufacturer, model, and display or button layout. For most LG refrigerators, it should be the "Refrigerator" and "Ice +" buttons. Hold them until they sound a beep to indicate a change in the demo mode status. It should not take more than 10 - 30 seconds.
If that does not work, and there are other buttons on opposite sides of the display, then try the other opposite pair of buttons.
Apr 05, 2013 | LG LFX25978ST Bottom Freezer French Door...
Can't get the stereo out of "demo repeat play" - it won't even turn off. If I unplug it, it automatically comes back on in "demo" play when plugged back in
It's in the manual, page 24.
DEMO
Press EQ master on the front panel in power off state to demonstrate the function in the display window. To
cancel it, press POWER or EQ master again.
May 29, 2011 | LG LFD750 Shelf System
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
"repeat demo play" is continuously
The manual on page 24 says:
DEMO
http://www.retrevo.com/support/LG-LFD750-Home-Theater-Systems-manual/id/17203ag405/t/2/
Dec 27, 2010 | LG LFD750 Shelf System
TruMotion Demo
If anyone else has the same problem it can be sorted by going into the main menu - select display - select advanced at the bottom of this screen - in this menu you can turn on/off the trumotion demo.
Jan 29, 2009 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
TruMotion Demo.
Hi Harry,
From the Picture Menu, the option at the bottom is Trumotion demo. Highlight this and press enter, turn demo off, press return.
Let me know if this helps and please rate this solution.
Lone99star
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
