Question about Husqvarna 28cc Gas Line Trimmer
Husqvarna weedeater idles, but stalls out when i give it gas
    Scholar:
  • 81 Answers
Clean the carbon from the muffler and muffler port. The carbon build up from the oil/gas mix has cut the air flow from the engine.
Posted on Jun 19, 2009
2 Suggested Answers
  • 203 Answers
SOURCE: i have a Shindiawa T-27 weedeater.Everytime i give
Depending on how old this unit is, you should be able to adjust the hi/lo speed needles on the carb. If it is so new that they have a strange head rather than a screwdrive slot, you will have to experiment to find something that will turn them. Sounds like you are not getting fuel when you open the throttle. Other than that, probably a carb cleaning would be in order.
When turning the fuel needle, you just want to turn it about 1/4 turn then try to give it the gas. You are going to be turning it out, or counter clock wise. Once you get it so that the engine will rev, try giving it fuel 2 or 3 times very fast. If it bogs down or acts like it is going to die, adjust the needle a bit more.
Posted on Oct 25, 2009
Husqvarna weedeater overheating after unclogging exhaust
Were any of the cooling fins damaged? This is a totally air cooled unit, air flow and fins are required to keep the unit cool. Make sure the fins on the cylinder and head are clean, the blades on the coil are clean, also check the spark plug to make sure it is the recommended plug, is the muffler clear? check airfliter and always use pre-packaged fuels.
Only other cause would be the carb has been set to lean, but I doubt that.
Jun 10, 2017 | Husqvarna Garden
The only reason for a brush cutter to over heat is because the engine is running too lean, this may be because the fuel filter is blocked, or the fuel hose is leaking, or the carb is set to lean on the carb mixture screws,
Jul 19, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Brand new weedwacker keeps stalling when i give it gas
try giveing it about a quarter choke untill it warms up.
Jun 26, 2012 | Husqvarna 128 LD Weedeater
Husqvarna 55 idles but stalls with gas
Most likely the diaphram in the carburator is bad.
Mar 09, 2012 | Husqvarna Garden
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
Nov 25, 2011 | Husqvarna Garden
Weed eater starts and idles after it warms. When I accelerate it sounds like it is choking itself out or it is starved for gas then stalls.restart and it does it all over. Sometimes it stalls when i go to...
Take out carb and spray with carb cleaner through and into all portals. Blow out with air compressor.and reassemble.
Adjust idle and low and high mixture screws according for proper operation.
Aug 31, 2017 | Weedeater Set (Weedeater)
I have a 128cd. The weedeater starts good but keeps stalling when switched to the full run position.
possibly a fuel starvation issue. check carb settings and possibly clean and replace diaphragms if needed.
Jan 25, 2011 | Husqvarna 28cc Gas Line Trimmer
Weedeater stalls when I try to give it gas, even after sufficient warm up time. Only way it runs is on half choke at idle. Don't see any adjustments except idle speed on the carb. using fresh gas mix.
If this is an older model, it may be in need of a carb rebuild. The ethanol added to our modern-day gas takes the life out of the small parts and diaphragms. The part that is probably causing you trouble is the fuel pump and they make some of those out of mylar (same thing drum heads are made of). It has to flex and that darn ethanol dries um out after awhile. They do have diaphragm and gasket kits for the 2-cycle carbs as well as complete rebuild kits...none TOO expensive,.
Jun 12, 2010 | Garden
I have a Shindiawa T-27 weedeater.Everytime i give it gas,it stalls.Idles fine but stalls as soon as you hit the gas.i put clean gas a new plug in it no good.
Oct 21, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 28cc Gas Line Trimmer Logo
4,803 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
