SOURCE: Hi I need the hadware disc for sony portable minirecorder mz-n505
Go to Sony Support and check downloads area where you can get driver and SonicStage for your MZ-N505 Sony walkman.
SOURCE: Recording from computer to a Sony MZ-R55 mini disc
You can use RK-G136 or RK-G129 cable to transfer music in MZ-R55, insert cable in Line-In terminal.
SOURCE: Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
SOURCE: I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
SOURCE: Looking for Sony minidisc player MDS JE480 parts
Best bet is an online auction like ( e Bay).
