Question about Drills
90564324 looking for the fwd/rev button for a kr705 drill
3 Suggested Answers
Tnsiouxfalls
  • 617 Answers
SOURCE: Need to repair a broken fwd/rev switch on a B&D
http://www.toolpartsdirect.com/blackdecker/blackdecker-7.html
Parts (above)
http://blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=15636
The Black and Decker site.
Posted on Jan 29, 2010
  • 412 Answers
SOURCE: 760H projector will not go fwd or rev either from
The problem you are experiencing is caused by a broken cycle solenoid "link". The "link" connects the solenoid plunger to the slide change mechanism. Over time, the "link" (made of plastic) gets brittle, cracks and the projector stops cycling. Parts are still available (www.micro-tools.com), but this requires an experienced hand and a service manual. Once done, your projector should be good for another 20 years !!
Posted on Jan 03, 2011
Broke fwd/rev Button
OEM Replacement Parts DIY Repair eReplacementParts com
Should have the parts but you will need to put in the model number. That will give you a schematic from where you can get the part and also order it from them. At times they will also have a video on how to make the repair.
Feb 28, 2014 | Black & Decker 18V Cordless Drill/Driver
Trigger stays stuck when pressed have to tap it to loosen it up,any solution will be appreciated.
REPLACE THE SWITCH OR DRILL APART AND FIND OUT WHATS CAUSING IT TO RUB ON THE HOUSING, SOMETIMES THE FWD/REV SWITCH WILL CAUSE IT TO HANG UP ALSO
Jan 07, 2011 | Dewalt 18 Volt 18v Cordless Drill Switch...
Need a starter for 3 phase motor with only two buttons, one for farward & another for reverse.button should be bell switch type, when presssed and hold, motor should run and should stop when released.
You will need a fwd-rev starter (has two contactors) You can buy any brand. You should have three buttons fwd stop rev
You could wire it so the fwd latches until stop is pressed, and the rev button momentairly so it stops when finger is removed.If you buy a brand with a general purpose (NEMA 1 ) enclosure you could put buttons in the cover, some even have buttons made for their covers.
Aug 11, 2010 | Garden
Set the clock on a jvc KD s670 car stereo radio?
Press and hold SEL until menu appears
Using the (SSM) / scan (FWD/REV) button , select Clock H
Using the volume knob/button, set the value
Using the scan (FWD/REV) button , select Clock M
Press SEL to save and exit
Jun 15, 2010 | JVC KD-S670 CD Player
How to set my clock on jvc car cd player
Using the scan button (FWD/REV), select Clock H
Using the scan button (FWD/REV), select Clock M
May 06, 2010 | JVC AM FM CD DET FACE CAR STEREO
Setting the clock how to do it?
Using the volume knob, set the value
Jan 10, 2010 | JVC KD-G720 CD Player
Set clock jvc kdg400 car stereo
Nov 07, 2009 | JVC Sirius KD-G400 CD Player
Motor runs on
They have issues with there switches.Depending on model # check for recall. This is a safety issue.
Jul 04, 2009 | Hitachi Drills
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
