Question about Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
I need to program channels with no remote
Or find a compatible universal remote
    Sergeant:
  • 239 Answers
Search for a "Toshiba MW20FP1 TV Remote" on Amazon.com.
Posted on Apr 19, 2014
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
My programmed my universal remote got all channels at first. Then something happed and I only get 1 through 13 now. Does anyone know what I should do to get them back? Could it be the remote controll is...
hi there! pls try this:
1. try to buy a new remote control compatible with your standard tv., when buying try to consider the name and model number of your television in this case the store will find a new one compatible for your unit. Universal remote control will do help too but some of its functions and programs will not because it is not totally design for it.. I hope i can help you a little with this . Thank You.
Feb 07, 2011 | Televison & Video
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
Need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Jun 17, 2009 | RCA Universal Remote Control
Buttons to push on universal remote to program channels
There are 4 methods to program your remote.
CLICK HERE for the user manual
Thanks for using FixYa - a FixYa rating is appreciated!!!
Jan 31, 2009 | RCA Universal Remote Control
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
My tv remote stopped working
Try using words to form sentences next time.
Don't lose the remote; tie a scarf on it with a key-finder in it and a pesto or frosting saran pack in the battery compartment if you have to.  You do.
Because now, you get to go buy a universal remote and program it, or use a universal remote program on a PalmPilot, cellphone, or IrDA-equipped PC.
Alternately, you could take advantage of any automatic input priorities the TV set has which are compatible with your game cabling.
Dec 26, 2007 | Symphonic WF104
MANUAL BUTTONS
Check the manual page at the link below for instructions on how to use the on screen menu to add channel 3 to the "active channels" list.
http://www.fixya.com/support/p197903-apex_digital_at3208s_32_tv/manual-18780/page-10
Dec 02, 2007 | Apex Digital AT3208S 32" TV
The universal remote does not bring up the menu so I can program all the cable channels in it. I don't know what to do. It is only receiving non cable channels. Help me so I don't have to keep watching...
alot of universal remotes dont let you program your tv with them due to how much more mem they would need. you have to use your actual tv remote or do it manually with the tv. sorry
Jul 29, 2007 | Sharp 13VT-R100 13 in. TV/VCR Combo
Toshiba MW20FP1 20 in. TV/VCR/DVD Combo Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
