The Product Analysthttps://theproductanalyst.com > TV
Oct 5, 2022 - Before you program your universal TV remote, make sure that your remote is functioning properly with full batteries. Also, check if your remote ...
The universal remote code for Astron TV can be programmed using the following list of codes:
672
673
075
094
091
000
0048
0042
0041
To program your universal remote to work with your Astron TV, follow these steps:
Aim your universal remote toward the Astron TV.
Press and hold the "SET" button until the small light on the remote control illuminates.
Enter the remote code using the numeric keys.
Upon entering the correct code, the remote light will turn off.
For Astron TVs, the Chunghop universal remote is recommended due to its compatibility and easy programming. Alternatively, you can try a GE universal remote, but you'll need to program it without specific codes.
If you encounter any issues with your Astron TV remote, such as it not working, consider resetting it to factory settings.
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
you definately do need a remote being a programmed universal one or just the one that comes with the converter box..either way theres no way of programming it..sorry learned it the hard way..good luck and by the way..make sure that you check that the remote youll be getting was made after 2009 and or thatll be compatible with a digital converter...
This is a universal remote u bought wright?Check ur tv remote owner manual follow the instructions and program in ur tv universal remote codes for ur tv universal codes.If none of the tv universal codes of ur tv model will work,return it.Try website like Remotes.com to buy the tv original remote or very close compatible to the original one.
Programming remotes for your devices (TV, DVD players, digsat/cable boxes/DVRs, etc) can be done often in an automatic (auto-code search) or manual (you input the code) mode.
Here are some pages that will help you choose the automatic and manual mode.
