Question about Toshiba CZ32V61 32" TV
No picture; black screen; only red light blinking.
Almost 9 years old - worked great until yesterday. Sometimes if the TV is moved around, will get snowy screen and then cable stations come back. Removed old cables and attached new ones, but this did not help. Something must have come loose inside. When it works, sound & picture still great. What would be the approximate cost to repair?? Or better to discard and purchase new one?? Thanks much.
  • dabbspat Jun 19, 2009
    Thanks so much to vijay_vinoo8 for the reply. I will call for repairs. (I don't want to have to deal with shopping for a new TV right now.....)
  • 240 Answers
Take to a service station i think just changing the displsy IC would do . but check in service centre
Posted on Jun 19, 2009
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
TV flashes to black and back again, no remote control operation..
I had the same part replaced in my KDF-42WE655 (3 YEARS OLD) television about 6 months ago and it was covered under an extended warranty by Sony because of a defect found in the part after manufacturing which Sony found will malfunction after time causing multiple issues with the television. My issue was the bottom of the screen started to get a blue dot that was getting progressively bigger. I bought the extended warranty from Best Buy and the problem was fixed no charge but the technician told me that Sony is aware of this issue and they extended the warranty on this part because of it. I would start by calling Sony and letting them know of this issue and see if it's covered under this extended warranty. Hope this helps
Apr 03, 2009 | Sony KDF-42WE655 Television
Bush 32" TV. desperate situation. T-T
The TV is in protection mode. An internal problem was detected and the set shutdown to prevent further damage. If the set is only 9 months old, it should still be under warranty. Call and request warranty service.
Dan
Sep 30, 2008 | Bush 5693D 24" TV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Tv Problem
check the circuit board for possible loose connection,try to resolder the horizontal circuit and the crt board.
Jul 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking led light on Toshiba
wow i must be another one with this toshiba common problem bug. Has anyone even remotely helped on this site?
Feb 27, 2008 | Toshiba TP50F50/51 50" Rear Projection...
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
Toshiba CZ32V61 32" TV Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
