Question about Depo Auto Parts Honda Civic New Radiator Cooling Fan Motor 1992 1993 1994 1995 1996 1997 1998 OEM 19030-P08-013
Does a radiator cooling fan blow air towards the radiator?
  • 3 Answers
No it draws air through from outside to inside the engine compartment.
Posted on Dec 06, 2014
Hi, i replace the thermostat and water pump flashed the radiator has coolant but still overheating, what else could it be its golf 4 tdi diesel 2002. Thank you
Radiator may have rust/salt deposits inside, if that is case its cheaper and better to change the radiator. Also for future don't use normal tap water in radiator, use a coolant + ph balanced water meant for radiators to reduce salt buildup inside radiator.
Also check the radiator fan is working ok and rotating in the right direction, sucking cool air inside not blowing out hot engine air to the radiator. Some electric fans can have wires mixed up so they start in the wrong direction. (make sure fan is sucking cool air outside towards the engine).
In some cars, radiator fan has a top cover that stops hot engine air getting sucked by the fan, if your car has it, make sure it is fitted properly and is in good order.
Some cars have a fan fitted on the AC condenser, make sure this fan is working as well.
Oct 01, 2016 | Cars & Trucks
Let's pretend you are an object. If you always saw the exposed side of the pictured fan, would you be the radiator, or would you be the engine.
This is not rocket science or law. this is auto mechanics. It has all been done a few million times a year before you. Please keep it simple! Find me and Randy helpful please. Youtube is your friend. lets-pretend-object-always-saw-exposed-u40lsvyytnuesyuv3fbafhtd-4-0.jpg
Jan 03, 2015 | 1987 Ford Ranger
Is the cooling fan a pusher or puller on a 1999 lincoln town car
Unless your blowing air or pushing
it toward the radiator you have a puller
Jan 23, 2013 | 1999 Lincoln Town Car
Does radiator fan blow towards or away from radiator
Toward.
During normal driving, the fan will be off, because air is being pushed through the radiator. When stopped, the fan will cut on, pushing air through the radiator and cooling the engine.
Also, make sure the radiator fan is on the inside (engine side) of the radiator, so it is not blocking the air during normal driving.
Jun 19, 2012 | 1986 Toyota Corolla 1.3
The car over heats while idling then cools as you drive
its the radiator fan running? check the fuses.
if the radiator fan does not run when the car achieves certain temperature, then your temperature sensor maybe defective.
check if you have enough coolant.
Apr 27, 2010 | 1997 Honda Accord
I have a 1995 cadilac elderado that keeps over heating, it has excessive preasure building up we have changed the thermastate, ran a hot wire to the fan so it always runs , changed tempature sending unite...
When the engine is cold,and the radiator is full,starting the engine,does it blow out the radiator?If it does,then a head,or head gasket is blown.If not,bleed the system of air.The engine cooling system might have air that needs to be purged out.
Oct 06, 2009 | Cadillac Eldorado Cars & Trucks
98 v6 mustang is over heating its not the thermostate or fan
Several things ... best guess, in order:
1. (very likely) Radiator fan is not blowing (turn on car and a/conditioner.
When compressor kicks in, the radiator fan must blow). If it ims not blowing,
the radiator fan motor may be burned out ($40).
2. Check / replace "cooling fan" fuse ($1) and / or "cooling fan" relay switch
($7).
3. Radiator clog (possible)
Hope this helps!
Sep 22, 2009 | 1998 Ford Mustang
Radiator Cooling fans pull or push air (93 Chevy Lumina 3.1 L) ?
A radiator fan is designed to pull air to pull air through the radiator to help cool it, while blowing the air on back across the engine to try to assist once again at keeping the unit running cool as to not over heat.
Apr 14, 2009 | 1993 Chevrolet Lumina APV
Correct direction of cooling fan
toward the engine, so as to pull air across the radiator.
Mar 30, 2009 | 2000 Mazda MPV
Fan motor blows air toward the grill
The rad fan should **** the air through the grill from front to back. Best of luck.
Mar 22, 2009 | 2002 Jeep Grand Cherokee
Depo Auto Parts Honda Civic New Radiator Cooling Fan Motor 1992 1993 1994 1995 1996 1997 1998 OEM 19030-P08-013 Logo
95 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Todd Arndt
Todd Arndt
Matthew Spark
Matthew Spark
Andrew Taylor
Andrew Taylor
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
