Question about Tw Steel TW 3 Watch
Recalibrate watch small hour dial will not recalibrate
My wenger sport elegance chronograph watch stopped working after 2 months. I bought it brand new. After readjusting the time, it worked for about 8 more hours, and then died again. The small dial on the...
You should change the battery, it is the cheapest thing to try. The batteries can be very old before they are installed and could have been in the watch a long time before you got it.
Sep 30, 2013 | Wenger Sport Elegance Chrono White Dial...
How does calender works?
Normally, the dial on the right hand side of the watch has two modes when it is unscrewed- time and date. Pull out on the dial until you hear or feel a small click. Turn the dial a little; if it moves the hour and minute hand then you need to pull out again. When on the correct setting, turn it until you have the date on the right number!
Jun 01, 2011 | Orient CEUAA002WW Wrist Watch
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
How to sethour and minute
Thank you for contacting FixYa.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Best regards. Jewel
Sep 02, 2010 | Fossil FS2919 Wrist Watch
How to set date on it?
Aug 25, 2010 | Fossil BQ9177 Wrist Watch
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
My first easy reader timex watch beeps every hour
mcdevito75 here, The beeping may mean the battery is weak, even if the watch is new. Look for a small watch repair shop in your area.
Jul 21, 2010 | Timex 27191 Wristwatch
Just bought a Fossil FS4446 sports chrono but it looks like the hour on the chrono is stuck just after 19 on the small dial on the right i just want to check that this is indeed the hour dial. and if it...
The small dial on the right is 24 hour counter and it does one full circle in 24 hours. The purpose of this counter is to tell the wearer what part of day or night is exactly (p.m. or a.m.). There are some places on our planet where the night/day lasts for months and it would be difficult to realise it's morning or evening without 24 hour counter. Try to advance watch hands forward/backward for few hours and you will see this counter hand moving. If it does not move, your watch has faulty/broken wheel and needs to be sent back for replacement/repairs.
Jan 27, 2010 | Finis Watches
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Tw Steel TW 3 Watch Logo
12 people viewed this question
Top Tw Steel Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tw Steel Watch Expert? Answer questions, earn points and help others
