Question about Samsung ML 1610 Laser Printer
Fuser low heat - Samsung ML 1610 Laser Printer
2 Suggested Answers
JaredKBerg
  • 19 Answers
SOURCE: Engine Fuser Low Heat Error
The fuser is responsible for heating up and transferring the toner to the page. Possibly the low temperature light is telling you that it is about to fail (it is a replaceable part) or warning you that this could be the cause of print quality not being what it normally was.
Posted on Jul 30, 2009
Solutions for "engine fuser low
The "fuser" should heat-up to its operating temperature to "melt" the dry toner-ink onto the paper.
If it is not heating up, then each page you print and brush with your fingers will remove the toner.
So, replace the fuser, or get it professionally replaced.
May 15, 2011 | Samsung ML-3561N Laser Printer
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Fuser Error. Low Temperature
there is a small thermometer that contacts/sits very close to the metal heat roller on your fuser, chances are when removing the jam its been bent away from the roller, have a look and try and see if you can see it, not knowing this exact printer im not sure the exact position but it is usually in the middle of the roller coming from the top of the fuser housing, another thing to check is if your fuser is actually warming up atall, if you cant feel any heat then the fuser lamp that heats it up has gone bad
Nov 14, 2009 | Xerox Phaser 6100/BD Laser Printer
PRINTER LOW HEAT ERROR
Low heat means either the fuser is not heating up or it is not sensed properly. you can find a new fuser at www.precisionroller.com but the low voltage power supply could be bad as well.
Oct 29, 2009 | Samsung SCX-4100 All-In-One Laser Printer
You need to replace the fuser in the printer, the part number is JC96-03406A You can do a google search for the best price.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Samsung ML-3561N Laser Printer
Low heat fuser
The fuser is not heating up, a lamp could be out, but usually the rollers are worn and it's best to replace the fuser completely.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
Canon copier error message "error001"
"E000" Low fuser temp. (Heat lamp, thermoswitch, thermistor, SSR) "E001" High fuser temp. (Thermistor) "E002" Fuser temp. too low "E003" Fuser temp. too low "E004" SSR, Fuser temp too highchange thermistor in fuser
Aug 27, 2008 | Office Equipment & Supplies
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
I have just replaced cartridges and am now getting fuser low heat error.
Yes, either the lamp in the fuser is burnt, the thermistor (heat sensor) on the fuser is burnt, or the low voltage power supply is not providing enough voltage to the fuser lamp. Your safest bet is to replace the fuser.
BUT!!!! The printer itself is let than $150 new with warranty, so if you like this printer I would buy a new one. A fuser will be between $90 and $150 and could be difficult to replace. If you get a service person to replace it you could expect two hours of labour at least which will be about the price of a new printer.
Jun 16, 2008 | Samsung CLP 300 Laser Printer
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Samsung ML 1610 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
