Question about Gateway Computers & Internet
Gateway Laptop it not powering with or battery or plugged in
I have a gateway laptop and it not powering up and the screen is black. This happen when it was powered by the battery and I changed it to power and still nothing!
    Scholar:
  • 155 Answers
Try to connect AC/DC power supply to your PC. If it works there is something wrong with your DC Battery. If you have done this, try to use tester to test if the power battery can still transmit power from source. If power is down, may be another kind of battery that is compatible to your PC. Insert only battery required for your laptop that would destroy your PC totally.
Posted on Jun 19, 2009
There is a problem with the power jack design on gateway laptops. The negative pin of the jack split around instead of made out of one solid piece of metal. Over time and with use, the outer shell of the jack enlarges and will stop contacting the power supply connector.
This problem is easy to fix with a small and flat screw driver. Proceed as followed:
1- Disconnect the power supply from the PC
2- Started with one of the negative pin split, insert the screw driver into the inner part of the jack
3- Steadily try to push the metal piece toward the center positive pin. Be careful not to break it.
4- Repeat 3 for two or more splits.
This should fix the problem until the jack is enlarges again. I know so because, I fix several gateway laptops with the same problems.
Miki Out.
Posted on Jun 21, 2009
Laptop black screen
what i would try doing is trying another charger this happened with my laptop when i was using my friends charger but make sure the voltages and amps are lower than the current charger you have
Nov 23, 2013 | Apple Gateway P-7811-fx Gaming Laptop Core...
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
Laptop black screen crash
I would guess you have a faulty power lead. They're not usually too expensive to replace - about 20 pounds in the UK. I'd try this as soon as possible as you don't want to damage your PC with a faulty power supply.
Nov 05, 2013 | Apple Gateway P-7811-fx Gaming Laptop Core...
Hi I have a serious problem with my laptop, sometimes the laptop will blink to a black screen and won't do anything. The laptop is still on but won't do anything so I am forced to hold down the power...
there might be a problem with your charger maybe it is giving in some extra power that your laptop is unable to handle...try charging it with another charger
Oct 27, 2013 | Apple Gateway P-7811-fx Gaming Laptop Core...
Gateway black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 04, 2012 | Gateway Solo 5300 Notebook
I have a gateway pc laptop that is 3 years old. It was working fine this morning. I had to manually power it down because my screen was frozen.(this happens from time to time) When I tried to power it...
Try removing battery and power cord let the laptop discharge. Plug the power cord in without battery after 1/2 hour. If it repeats the same thing plug a regular monitor into the vga output see if you get picture if so it maybe a lose connection to lcd screen or bad lcd screen.
Dec 30, 2009 | Computers & Internet
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
I'm betting that you need a new "Inverter" board, especially if it's a Gateway 450ROG.
There is an inverter that Gateway used in several models that has a known defect.
Inverters are relatively inexpensive ,and easy to replace. You could ven do it yourself if you have a little skill at disassembly / re-assembly. Tell me the model number of your laptop and I can help you more
Apr 10, 2009 | Gateway 40G / 40GB for laptops /...
Gateway M305 power adapter replaced by Gateway. Now blue screen
Try running it just on battery. Then take the battery out and just run if off the adapter. see what happens..and call Gateway and complain..if it doesn't run off the adapter then you really need to call gateway..cause you're stuck without a working computer.
Mar 22, 2009 | Gateway M305CRV Notebook
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Sep 30, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
298 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
