Question about Symbol LS2208-1AZU0300S Handheld
Part of code
I want to read only part of the code. From the sixth character up. I tried with the manual to scan the bar code that sets the reading from the sixth character. It does nothing. I tried with the software 123scan that is provided with the does nothing. well it does something. errors. when i want to comunicate with a program it says error open port failed (on all 4 com ports). i tried to install the software on another system, instalation error. help :)
  • 97 Answers
Re: part of code
The rule you tried applying initially is the right one, however, you need to know what symbology is the barcode that you have and apply it to that symbology in order to get it to work.
123scan will work but my recommendation is that after you created all the required rules rather than download the config to the scanner you print the configuration barcodes.
I hope this helps, otherwise get back to me and i will find another way to resolve it, however, i may need a sample barcode so i can analise it.
Posted on Mar 26, 2009
  • 244 Answers
Re: part of code
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS? I would like to recommend you to used visual basic 6.0 for better outcome.
Hope you like my solution please rate me Solved.
best regards,
Posted on Nov 05, 2007
0 characters
3 Points
Why doesn't it scan?
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
Jan 27, 2016 | Zebra Symbol LS4278, Bluetooth, Blood Bank...
How do I add CR to Barcode Value?
<p>The primary purpose of bar codes is to encode the unique characteristics of numbers and letters can be in a format that machines can easily read. However, bar codes are read by people often also for this reason, the codes generally include both parties readable and legible. The most popular bar codes meet a standard called "Code 39". The latest version of the code with 39 additional characters called "Extended Code 39." Among other characters, Extended Code 39 allows users to include carriage returns (CR) in bar codes. <br /> <p><br /> <p>1. Setting the bar code scanner to read "Extended Code 39," Code 39 is not as common support CR. The details depend on the specific bar code scanning software is used, but you will usually find this option under "Tools" then "Options." <br /> <p><br /> <p>2. Configure the software to generate bar code to the "Extended Code 39" is also used. The details depend on the specific software to generate barcode is used, but you will usually find this option under "Tools" then "Options." <br /> <p><br /> <p>3. Type "M $" (without the quotes) at the point where you want the CR model is within the barcode. M $ gives a CR Extended Code 39. <br />
on Jun 26, 2011 | Barcode Scanners
Why does Symbol LS 4000i put an X before data?
Someone mistakenly added a character before the data during the configuration.You may try factory default setting using configuration barcode.
Jul 07, 2014 | Symbol LS 4000i Handheld
I have a new LS4278. I need to congigure it to read fedex barcode
All you have to do is create a rule to transmit only the 12 digits you want.
You can create a rule with the Programming manual or the 123scan software.
Both of these are available online at Here is a short cut:
if you need additional assistance please let me know - Thank you, Kim Ganoe 800.933.2839 x251
Mar 05, 2010 | Zebra LS4278 Cordless Bar Code Reader...
Total available char can be scan
The number of characters read is defined in your application and the width of the printed bar code. Also the width of the laser or ccd. One program to develop applications JobGen Plus de Unitech.
Roberto Martinez
Aug 16, 2009 | Unitech PT630 Portable Terminal
Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
I can't programmed my IT3800LR
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
The factory reset bar code is on printed page 4 of the PDF document.
Mar 05, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Bar code reader problem
In the user manual for this device there should be a code book (or code pages), These are a selection of barcodes which you use to configure the device. One of the settings is to omit the barcode header (which indicates a type of barcode for instance a PART number might begin with P or a Serial number might begin with an S) This barcode system may have been initially programmed to omit these code letters Gareth
Jul 04, 2007 | HHP IT3800 Handheld
The problem with reading the barcode
Be sure the Flic scanner is set to the factory default configuration by scanning the Defaults bar code given above. Then check the Format options for Characters to Strip and Characters to Append (see page 10) and make sure these are set correctly. In order to scan the ?Factory Defaults? bar code in the Flic Operator?s Guide to reset your Flic scanner to the default settings: Select Flicware , Tools , Format and add the appropriate control character(s) in the Characters to Append box. Good luck.
Dec 05, 2005 | MicroVision Development HS2121-MV
Symbol LS2208-1AZU0300S Handheld Logo
280 people viewed this question
Top Symbol Barcode Scanners Experts
Brian Friend
Are you a Symbol Barcode Scanner Expert? Answer questions, earn points and help others
