Question about Acer Aspire 5735-6694 Notebook
High pitch sound
Hight pitch sound when I close the lid
  • 78 Answers
This sounds like the microphone is picking up feedback, if you are not using the mic then go to control panel then sound and disable the microphone
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Posted on Apr 22, 2014
High pitch whistle after closing door
It is possible that the door gasket is defective
Jul 01, 2013 | Frigidaire FFU17M7HW 17 cu. ft. Manual...
My whirlpool duet is displaying the error code 888. It works ine through all cycles but the time displays 888. All the lights are illuminated and there is a high pitch alarm sound that remains on until...
Please state brand and model of your washing machine for accurate and specific solution...
There is no 888 error code on my list of whirlpool..I think the 888 flashes is the time remaining..
If the lid opens while the unit is in running mode, time remaining will flash in the display.
Close the lid and press START to continue with the cycle.
Hope it helps..
Dec 03, 2011 | Washing Machines
I noticed an unusual high pitch sound which I traced back to the refrigerator. I then noticed that the front panel lights were flickering on and off and so was the external ice maker lid. I turned the...
Hi and welcome to FixYa, I am Kelly. First off the high pitched sound you heard was most likely ice build up on the evaporator so th evaporator fan blades were striking the ice. Now as for your shutting of the unit and staring right back up..... You need to wait 15 - 20 minutes of OFF time when ever there is a power interruption. What is happening now is that the compressor can not restart because the coolant pressures are to high. That 15 - 20 mins of off time will afford that pressure stabilization time.
What you really need to do is remove the freezer contents and place a fan blowing into the freezer compartment to manually defrost the freezer evaporator. (about 2 hours of floor fan time) This should get rid of the high pitched noise. Then.... restart the unit. It should restart.
I suspect that you have an automatic defrost problem is why you had the noise. The manual defrost will only get you 2 - 3 days of normal operation again before it once again starts the icing routine. I want to get this off now to get you started on the manual defrost. I will respond with a 2nd post about the defrost problem.
Your to do list...
1. unplug the unit.
2. Manual defrost with floor fan (2 hours of fan and water mess)
3. Restart the unit
4. Watch for next post about defrost.
Thanks for choosing FixYa.
Kelly
Dec 09, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
High pitch shrill when flushing
I had the same thing happen to my toilet. The quickest way to resolve the issue is to replace the fill valve.
Jun 15, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
High pitched sound from TV
Ur hight voltage flyback transformer is dead.
U need a new one.
Aug 20, 2009 | Samsung LN-T3253H 32 in. LCD Television
High pitched sound comes from tv ---no controls on tv work--you have to unplug it to get the high pitch to go away
Is this a tube tv?IF it is the Flyback tranformer have a little still bar tranformer hight current volt make that noise take off the tv cover put some glue on the little steal bar should stop the noise or lower it very good.
Aug 12, 2009 | Televison & Video
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
Micgain
Offhand, pls try:
  • If the high pitch sound (feedback) occurs during the receive, then you need to check the switch inside the microphone and verify that the audio line is not directly connected mic element wire; it should pass through the switch. Alternately, it may be the switch that is shorted. If you are using a power mic, you may have to lower the settings a bit or decrease the gain;
  • If the feedback occurs during transmit, you need to check the TX/RX regulator and switching circuitry. In some cases this would also be true if you are using a linear amp and the grounding is not adequate and/or the SWR relatively high.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 31, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Acer Aspire 5735-6694 Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
