Question about Philips FTR-9964 Tuner/Receiver for Plasma
Philips FTR 9964 tries to switch on but light above power switch flashes red
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Cannot swtich on the tv
I think you mean ' switch ' and ' only the red light ' ( power ) comes on.
It could be an internal trip on your tv set that needs looking at by a tv engineer ( normally parts required ) or if you have a tv with a ' factory settings button ' on it ( normally on the side or top if it's a flat screen tv ) press and hold for 10 seconds then the intial ' tv setup ' will appear on the screen ; after that, just follow the guide.
Hope this helps.
Jul 24, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
Jun 05, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
Phillips Plasma 42PF3320
I have phillips 42" plasma tv it has 7 red light flashes at start up and locks out
Jun 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
The reciever box light flashes red
Same issue here in NZ with a set.  Fixed (twice) before.  Same problem for the thirs time in 4 years. Solution  - get a Sony.
Feb 11, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
50 inch ambient light plasma
MY 2006 PHILLIPS AMBILIIGHT WONT POWER ON
50 INCH PLASMA
Jan 20, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Open Questions:
Televison & Video Logo
614 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
