My sony cdp-s207 skips a lot - Audio Players & Recorders
2 Suggested Answers
tvservice306
  • 458 Answers
SOURCE: sony cdp-cx235 cd skip
need replaced laser pick up part no:
Manufacturer Sony Part Number 8-848-415-13 Description DEVICE, OPTICAL
Posted on Apr 04, 2010
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
The music is skipping a lot on all discs played on the device
are there scratches on the disks if so i recomend replacement but the lens might be dirty if so you can go to a local walmart and purchase a cd/dvd cleaner and i have provided a link
 http://www.walmart.com/ip/Innovera-CD-DVD-Laser-Lens-Cleaner/14915544
Jan 02, 2011 | Sony CDP-CX400 400-Disc CD Changer
My Sony CDP-XA7ES CD Player can play only up to 6 to 9 tracks depending on the length of the tracks n then stops.
replace the spindle motor. the motor's speed varies while playing cds and a worn motor will not keep to the correct speed for playback of certain tracks on various points of the disc and will cause skipping and even stop altogether.
hope this helps.
Apr 02, 2010 | Sony CDP-XA7ES CD Player
CDP CX355 Seems to Skip- sound similar to what happens with LP record when dirty.
If the player "skips" after 15+ seconds the likely problem is the split rack&pinion used to position the laser. The split rack is sprung to remove play or backlash when meshing with the driver cog. This split rack can jump cogs over time, eventually becoming ineffective. The solution is to remove the laser assembly and gently disengage the driver cog, compress the split rack and re-engage the driver cog. This should solve the skipping problem.
Nov 28, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Music speeds up,skips pulsating noise
Ok, this is optical lens assembly failure. the lens assembly is a whole device that runs on a rail with rail motor. the spin motor is also attached to this Assembly as well. the entire assembly will need to be replace due to the damage that has occurred.
Replacing the optical lens assembly will fix all the issues you stated.
May 31, 2009 | Sony CDP-CX235 200-Disc CD Changer
Cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Jul 29, 2007 | Sony CDP-CX400 400-Disc CD Changer
59 people viewed this question
 Grubhead
Grubhead
