Question about Sewing Machines
My problem has not been posted its pineterest says machiine embroidery is free when you click on design it says undo not hqppy
I dont beleeive about problem being solved im still waiting for my answer which you say has been posted not true have no faith
  • Sewing Machines Master
  • 1,388 Answers
What is the question ?
Posted on Apr 22, 2014
With embroidery card inserted into module, no motifs appear on the display screen.
Here are two other possibilities other than electrical problems with your Bernina. There are embroidery design cards that were made for the 200 & 730 that simply do not work in a 180. There is nothing marked on the card or the packaging that will tell you what model machine the card will work in. I sold a bunch of my design cards on eBay last winter and I tested all of them in both a 730 and a 180 before making the ad discription. I found that most of the design cards worked in the 180 & 730, but there were a few that only worked in the 730. So if your design card is one of those that won't work in a 180, that could be your problem.
You did not say if you have other design cards that do work or there is only one you tried. Possibly the card itself is bad.
A static shock to the card could possibly damage it.
So if you take your machine to a dealer to have it looked at, take your design card along.
The 180's memory for storing designs is located in the embroidery module, not the machine itself. If that memory is filled up with other designs this can cause a problem.
So your problem is most likely with the design card or with the embroidery module. Should you need to get another embroidery module, that module needs to be the same version number as your machine or it will not work. I have a. video posted on YouTube that shows you how to check the version number of your machine and module. That information is in my "Bernina check hours 165, 170, 180, 185" video. Put that in the YouTube search box and you will find my video. Plus I have other helpful Bernina videos posted.
Aug 14, 2014 | Bernina Artista 180
Transferring DVD designs to USB stick for my Husqvarna Designer 1
First you need your 4D software installed on your computer (or which ever version you are using). Insert the DVD into your drive. Then open your embroidery program and then click File and Open. When the new window opens, search for your DVD drive then find the embroidery you want and click Open. The embroidery yoiu chose should open in your embroidery program with the hoop displayed on the screen. Then save the embroidery under a new name in your embroidery design folder on your computer. Then insert your USB into your computer, Open Disk Manager and Read your USB. Then click on one of the empty squares and then click File then Open. In the new window find the embroidery file you saved under a new name on your computer and choose it. It should show up in the empty square you clicked on. Then Write to your USB. Now you are ready to move your USB to your machine and the embroidery should be there. Hope this helps. Good luck.
Oct 17, 2013 | Husqvarna Designer I
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
How to stich embroidery
That would depend on if you have a regular home sewing machine or a embroidery machine. I'm going to assume that you have a regular machine.
There is something called free hand embroidery. you lower or disengage the feed dogs, take off the presser foot. Some use a darning foot and others just leave the foot off. Hopefully your design is already marked on the fabric. Place fabric in a regular hand embroidery so they fabric is right side up but the hoop makes it sit down in the rings. (make sense) Fit your hoop on the bed of the sewing machine, under the presser foot/presser foot bar. Lower the presser foot lever. (important for tension) and select stitch style and length. you may need to adjust tensions too.
Begin stitching, take a couple stitches... then reverse a couple... then snip the loose ends. Continue to stitch, guiding the hoop so that the needle follows the design. Start slowly and as you discover how your hand movements effect the length of the stitches... you can speed up and slow down as you need to create your design.
https://www.youtube.com/watch?v=ylMy6QdsZr4
Nov 03, 2012 | Sewing Machines
Can you please tell me the correct format for my computer embroidery designs? I have a Brother Innovis 900
PES
here are some free ones for you straight from Brother.
http://www.brother-usa.com/Homesewing/DesignStudio/Projects/DesignList.aspx
Sep 16, 2012 | Sewing Machines
Cant embroider on toyota quiltmaster 50
The Quiltmaster 50 can only do free-hand embroidery. Use the darning foot. Set the machine for a satin stitch with a stitch length of 0 and lower the feed dogs. Manually move the hoop to stitch your design. (Trace the design on the fabric and place on a stabilizer if needed. Center the design in an embroidery hoop and move the hoop under the needle. In my limited experience, all fabrics need stabilizers. Some require multiple sheets of stabilizer.)
Personally, I have trouble moving any fabric under the pressure foot. This is mostly a matter of practice. You have to make a lot of scrap piece trials.
This site has the manual for the Quiltmaster 50 (European version): http://www.home-sewing.com/WebRoot/Store/Shops/homesewing/4AAF/95FA/5ED9/1505/56BA/4D44/240A/754B/QUILT50_0020_EFNI_0020__0020_679111-CEA10.pdf . See page 37 (49 of the PDF).
I hope this helps.
(who actually cheats: I either use an embroidery sewing machine or I use a late 1960s Singer Sewing machine with its Monogramming accessory. This has pre-programmed designs on little discs. That's why I don't practice free-hand stitching.)
Jun 15, 2012 | Sewing Machines
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I recently purchesed a Singer Futura CE150 embroidery sewing machine and I'm having some broblems.I bought some embroidery designs off the internet from a co.by the name of embroidery library and the...
Multihoop and endless hoop features are not supported yet. If you have purchased a design that splitted to several parts, you need to place them in the proper order and from the proper position manually.
Dec 22, 2009 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
