Question about Zanussi FJS1225W Front Load Washer
Nothig showing on display of my zjd 12191 as if there is no power
Zanussi jetsystem ZJD-12191 TURBODRY washer dryer drum will not turn
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 22, 2013 | Washing Machines
Power button seems to be broken
the trigger has been damage you have to replace it .if you want i can fix it im a technician
Jul 18, 2009 | Washing Machines
The camera turns on but nothig shows on the lcd & can´t take pics
If hard resetting and restoring it doesn't work you have a broken LCD screen. There is a camera repair website that shows you how to replace the screen yourself and there are also third party camera repair services that do it for you.
Jun 14, 2009 | Samsung L700 Digital Camera
Screen problem
im afraid to tell you that your display has gone faulty there is nothig you can do apart from change the display contact the shop where you got your set from they should be able to help you.
Mar 10, 2009 | Norcent Technologies PT4231 42 in....
Need new drivers!
Try this site:
http://driver-pro.com/related/english/hardware-drivers/?gclid=CO6Glqbv9pcCFQ8Qagodlw8UEA&hit=1&adurl=12191
Jan 05, 2009 | ABS Computer Technologies Ultimate V2 50...
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Olympus FE 240 - downloading problems
Remove the Software
Restert the Computer
Plug camera in and turn on set it to the upload mode.
Windows will then fid it via the Camera/Scanner Wizard.
If there is still a problem
A cheap card reader will do the trick
Dec 13, 2007 | Olympus Camedia C-350 Digital Camera
Brother put a foil wraped burger in micro now everything is dead
Hi, You may want to try to check/troubleshoot the PCB underneath the display/control panel. The mains do supply two circuitries: the heavy load and the electronics. In some units, they have a standard transformer while in others an SMPS that supplies the +5 (and sometimes +12 or higher) voltage. This powers the electronics which includes a microcontroller, timer, relay drivers and display panel. Trace the transformer/SMPS and look for any fusible link, secondary fuse or surface mounted fuse. More often than not, there are also standard components along the way like bride diode, diode, filter capacitor and regulator IC. Check for VDC input and output of power components. Hope this gives you an idea, Pls post again how things turn up or if you need further information. Good luck and kind regards.
Aug 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Zanussi FJS1225W Front Load Washer Logo
19 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
