Question about Kitchen Appliances - Others
Prestige eco kettle red won't turn off second kettle that won't turn off boils dry??
2 Suggested Answers
  • 1416 Answers
SOURCE: Why does the water boiled in this kettle smell and
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Posted on Jun 01, 2010
Testimonial: "Glad to hear it's not my imagination. On complaining to the retailer they suggested that I have a very delicate palate, or do I have fillings in my teeth!!! I do, but my 85 year old mother sure doesn't. Thanks again."
Kettle not heating up water but electricity is reaching the kettle
How to fix an electric kettle part 1 - YouTube
? 4:51
https://www.youtube.com/watch?v=P4dcq5p0FyU
Apr 15, 2013 - Uploaded by Anthony Findlay
how to troubleshoot and fix an electric kettle. ... I am using akettle had small problem the switch was not working so I have tried to fix it but I am ...
HOW TO REPAIR ELECTRIC KETTLE - Fix Your Electronics ...
electronicsolutn.blogspot.com/2012/10/how-to-repair-electric-kettles.html
Oct 25, 2012 - Electric Kettle is a kitchen appliance that contains a heating properties used for boiling water, cook food etc. It is made up of a metal or plastic ...
electric kettle light but not heating Questions & Answers - Fixya
Dec 08, 2015 | Hamilton Beach 40996 Programmable 1.7...
Bulb in Ikon kettle no longer lights up
I had this problem recently; I think my kettle have accidentally been turned on empty. The kettle has a safety for that, described as follows in the manual:
"The kettle is fitted with a safety device, which protects against overheating should the appliance be operated with insufficient water. If this occurs the kettle will stop heating. Switch 'Off' at the power
point and allow kettle to cool before refilling. The safety device will automatically reset when the kettle has cooled down."
Then they go on to tell you that there is an additional thermal cut-out, and if that is tripped, you have to send it back to Breville for servicing. However, it might not be that bad-- it wasn't in my case.
The heating connector and control is made by Otter, here's information that I was able to find about it on their website (Otter A1 and CS7 control and connector-- I think the kettle actually uses a CS4 connector, but the thermal cut out isn't described on that data sheet):
"The A1 control integrates to 360° cordless plug with element
dry boil protection. Two bimetals spring loaded against the
element surface make a fast response during dry boil. One
bimetal disconnects the live side of the electric circuit and the
other disconnects the neutral. A latch out function prevents
dry boil cycling. This automatically resets when the kettle or
jug is lifted from the cordless base."
http://www.ottercontrols.co.uk/support-downloads/domestic-data-sheets
So what does this mean to you? If you look at the bottom of the kettle jug, there is a circular indentation that slots into the base. There are two white plastic things which I believe are part of the "latch out" described above in Otter's documentation. If you see them sticking out, they may be stuck in position instead of resetting as they should. Use something like a pencil eraser to gently poke them so they unstick, then put the jug back on the base. That should cause them to retract, and at that point your kettle should work again.
Nov 07, 2013 | Breville SK500XL Stainless Steel Cordless...
How to fix a kettle when the power switch switches off before boiling point?
There can be several causes. In many cases the power switch is thermo or current tripped, It is like a thermo circuit breaker.
The power switch itself may have to be changed.
The element is pulling too much current.
The thermostat may be defective.
Contact the manufacture to find out where you can buy spare parts to try. You will require the proper connectors, and crimp tools to work inside of these. Also, you will require a sound knowledge of how these appliances work, and the safe way of servicing them.
Because of the way you asked the question, I would think you are not familiar with how to service these devices. I would suggest to give the kettle to a service rep, or to purchase a new one. There are safety issues when servicing appliances.
Jerry G.
Jun 24, 2012 | Prestige Appliances Prestige Pf Enamel...
I have a new Bellini electric kettle. When I turn the kettle on, it starts to boil for a few seconds and then turns itself off. It will boil if I hold the "button" down for a while until it...
Unfortunately the problem is in the switch mechanism, and will need to be replaced to correct the problem. My sense is it would be cheaper to replace the kettle than trying to find somebody to repair it.
Mar 13, 2011 | Kitchen Appliances - Others
Kettle does not automatically shut off even when water is at above minimum level and boiling
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
May 15, 2010 | Chef's Choice 677 Cordless Electric Kettle
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
