Wiring diagram asv positrack rc100
Wont wind over
    Sergeant:
  • 181 Answers
Hello. If you have the factory manual, look through it first, if you can't get to do right, call aairconditioner expert to help you.
Posted on Apr 19, 2014
Asv rc 100 wont start
Hello. Make sure the fuse breaker is not blown. If it still does not want to work, call a air conditioner expert.
Apr 19, 2014 | Heating & Cooling
Manual
Go to the Raymarine.com website, they have manuals for their products even ones that have been discontinued.
May 10, 2013 | Raymarine ST40 Wind System Rotavecta...
I need a diagram on a skoda1.9 octavia 2003 car on how to fix the eletric window winder regulator wires
library has chilton and mitchell books------or go to magicmechanic online and send him the problem
Jul 27, 2012 | Cars & Trucks
This is a question for anyone who will know the answer. http://www.fixya.com/support/t2331151-old_capassitor_3_prongs_new_capassitor_2 our problem is the same however there are only 3 wires on the new...
3 wire capacitors are usually supply ( Power in), start winding and run winding. If the wiring is mixed up, the compressor wont start. On some machines, the capacitor is a multi feed cap, which supplies power to the fan as well as the start winding of the compressor. I suggest you contact someone who can read a wiring diagram to determine which one you have. All Makes usually have a wiring diagram behind or near the cover plate where the electrical terminations are.
Jul 03, 2011 | Heating & Cooling
Need instruction manual
The Owner's Guide for the RC100 / RC101 10 cup Rice Cooker can be found here:
http://www.rivalproducts.com/manuals/MANUALS/RC101_43_25285476.PDF
Jan 09, 2011 | Rival RC100 10-Cup Rice Cooker
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Wiring diagram for electricmotor with capacitor
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Apr 01, 2010 | Heating & Cooling
Older sears bench grinder wont run 1/3 hp model 397 19581
I know this is an old post, but maybe it will help others looking for information.
I have the Craftsman 1/3-HP grinder models: 397.19580 & 397.19581.
They are Split-Phase single voltage (115 V), and use a Klixon start-up current style relay - 2CR14-224.
The relay is normally open. When the large starting current in the main/run winding circuit is sensed by the the relay coil (term 3 & 4) which is in series with the main winding, the relay contacts close (term 2 & 4).
The one end of the start-up winding is connected to the main coil's BLK wire in the coil pack.
When the relay contacts close the start-up winding is energized. The start-up coil is used to provide a boost to over-come the resting inertia of the rotor.
Once the rotor reaches between 65% - 75% of operating speed, the current through the main winding circuit is reduced to the point that the relay coil cannot over come the return-springs force, acting on the relay contact arm. With the contacts open, the start-up winding is no longer energized.
This should take about 2-3 seconds, if the relay malfunctions, the high current through the start-up windings (thin wires) may be damaged.
Here is a diagram I have made.
Klixon 2CR relays are no longer available.
You may find a suitable replacement here:
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_
May 31, 2009 | Craftsman 6" Bench Grinder with Lamp
L need the wiring diagram for an GE washing machine motor model #5kh4zdt74s it has 5 wires colored ( black, white, yellow, orange and blue ) the orange goes to a bi-metal circuit breaker either for...
I was unable to find your model but maybe there are some other clues to the model's number you can use on this web site.
http://www.geappliances.com/service_and_support/literature/
Also all washing machines include a wiring diagram underneath the control panel at the top. Unscrew from behind and the sides and remove, be careful of the wiring. You don't want to pull a connection out.
Mar 05, 2008 | Washing Machines
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
