Working together Ive got a Bush DLED32165HD and a Bush BU11FVRSD32/X Digital recorder. Connected up on screen it says (connecting to host). But on top of screen searching update PC/UART
3 Suggested Answers
  • 34186 Answers
SOURCE: My bush dled32165hd won't turn on from standby all
Could be power supply failure.
Posted on Sep 26, 2014
gopakumarg43
  • 74136 Answers
SOURCE: Sharp LC-26AD5E-BK Upon switching TV on screen displays: "Software Update through PC/UART" & "Connecting to host". TV is non responsive to remote control and am unable to exit screen. Please help.
Try a hard reset to this set, and then check. If it do not help you; contact the authorized service center for sharp. Firmware update might be necessary.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Jun 15, 2016
Hi Shaun I've tried reinstalling my channels like 10 times and still nothing. The model number is bush dled32165hd
you either have a fault with your aerial or there's a fault with the tuner on the tv, thanks
shaun
Feb 22, 2017 | Bush Televison & Video
I have a bush dled32165hd tv and ny remote has broken a reminder popped up and i am unable yo change back to my sky box from the built in freeview is there anyway to manually press select
There should be a button on the left hand side of the tv.
I can't attach a link properly but the one below takes you to the correct page in the manual. If it doesn't, you need chapter 8.
http://www.manualslib.com/manual/982577/Bush-Led22134fhd.html?page=8#manual
Aug 17, 2016 | Bush Televison & Video
The screen flickers and darkens while watching the TV. It is a 3 month old Bush DLED32165HD. Adjusting contrast/brightness/sharpness makes no difference. Turning off the TV and turning it on again, th
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 14, 2015 | Bush Televison & Video
Screen shows blue box with 'software update through PC/uart
My bush bu11fvrsd32/X is show this on the front software update through pc / uart how can I get it of
Mar 16, 2014 | Televison & Video
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
Nds lite not working
Youve damaged the top screen cable - nothing to do with wifi block
see www.dsdoctor.co.uk
Jan 31, 2009 | Nintendo DS Lite Console
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
