Question about Ovens
PON663W oven manual
Need to know how to reset the oven...or where can I get a manual for a PON663W
OVEN TRIGGERED THE BREAKER TO GO OFF AND NOW THE OVEN IS NOT WORKING.
First thing is to reset the breaker, it's tripped right now, so turn it on then off again then back on. If it kicks right back off again leave it off as you have a dead short and that can be dangerous especially with an electric oven. In that case call an appliance repair person.
If the breaker stays on after you reset it go back to your oven and see if it has come back on and is working. If it has power but the display is flashing some error code you will need to troubleshoot with the owners manual or look online for a manual.
If the oven is only a few years old it should "reboot" itself when power is restored. Some models require that you manually reset them with some combination of buttons (that's where you need the manual).
I hope this helps.
Jul 30, 2014 | Whirlpool RBD305PD Electric Double Oven
Manual for a Westinghouse oven 667.
The manual you are looking for is over here:
http://manuals.appliancesonline.com.au/westinghouse-electric-wall-ovens/westinghouse_electric_wall_ovens_manual.pdf
The manual includes multiple ovens including yours.
Mar 28, 2012 | Ovens
My oven wont heat up after i reset it
When you refer to resetting it are you talking about turning the mains power off and then back on?
Or are you talking about resetting the electronic timer? The electronic timer must be in the manual mode for the oven to work. Turn the oven on and play with the timer. When the oven indicator light comes on you know the oven is working.
Feb 13, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Since a power cut yesterday, our Tecnik 8522 oven has flashing 'A' (Auto) on the clock & the bottom oven does not work. I know I have to reset the time to get te A off but no buttons work on the facia...
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Feb 10, 2011 | Ovens
We have lost the manual and need to know how to reset the clock and its functions
Go to NEFF website where all manuals are downloadable. Use link on bottom left of page.
Jan 31, 2011 | Neff U1421 Double circotherm Electric Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
The oven will not operate after I switched the mains power off. The clock is flashing 0. Any help appreciated !
I dont know your model but it seems like the clock needs resetting if you have a manual it will tell you in the book.if not just keep pushing buttons. normally holding the 2 on rhs then pressing other buttons can do it keep fan oven switched on as you try to reset
Hope this helps.
Good Luck.
Apr 11, 2010 | Ovens
I have a older Frigidaire oven model #RG74BC. I have messed with the timer knobs and the oven will not come on. Does anyone know what setting the knobs need to be on to fix this problem
You have probably inadvertantly put the oven into Automatic cook mode, where the oven will not come on until a preset time.
Try pressing/turning the clock/timer buttons and resetting the clock and this should put the oven back into Manual cook mode and you should be ok.
Jan 10, 2010 | Ovens
Kenmore propane range/oven tripping GFI
My bad, yours is an oven.
I found the Owner Manual, but could not find the Installation Manual. Do you have it, and does it say to hook the oven to a GFI protected power source?
Just because of the way the electronics work in the oven, and the way the electronics work in the GFI, I don't think that they work together. The oven is a permanent appliance, so I don't know of any reason it would need it.
How long have you had this oven installed, and connected to the GFI? Has anything changed, like you washed the oven down and got water inside it. Is a non GFI circuit available nearby where you could wire the oven?
Let me know what you find. It's been awhile since I looked at a new Electrical Code (NEC) book, and even with that, you local ordinances can over ride the NEC.
Jan 29, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
May 27, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
21 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
