Emachine notebook doesn't recognize my wireless network.
I recently bought an emachine notebook on sale.
It is the G725 model.
I set up Vista and did all the other necessary configuration. Everything went fine until setting up wireless connection.
The notebook doesn't recognize my home wireless network but can see all the surrounding networks. I tried connecting right next to my router with nothing occurring. I also tried connecting it using a LAN cable and that enabled me to access the internet.
I tried doing the manual addition of the device to the network but with no results.
I've tried several walkthroughs to fix this but ended up with the no progress.
My wireless router is a D-Link
- WPA-Personal
- TKPI and AEP
    Problem Solver:
  • 11 Answers
Try running the Microsoft updates or getting updated drivers for your wireless NIC. It's even possible that the wireless card in the laptop doesn't support WPA security. Unlikely seeing as how the board is fairly new, but possible. You might also want to try getting a PCMCIA wireless card and popping that in.
Posted on Jun 19, 2009
I reinstall emachines g725 and cant see wireless, how can i fix it
You will need to install all of the drivers before you can even go online.
Jan 05, 2014 | eMachines Computers & Internet
I cannot see the icon of wifi if i already connected to it. how to sset up wireless connection on my laptop?
Hi Jerome,
Which operating system are you using? If it's Vista/Windows 7...
1) Click "START" and in the search area, type in "Network and Sharing Center"
2) Select it, and look for "Manage Wireless Networks" in the left hand column to set up wireless connections.
3) ...and go from there to add/modify any wireless networks you want to join or have already joined.
Hope this helps
-BuzzPuppy
May 01, 2011 | Acer eMachines E7254520 Notebook PC
We just bought a new emachine, Acer E627, with windows 7. I cannot connect it to our home network using a D-Link DIR-655 router. It has always worked fine. Other computers can connect to OUR network, we...
WPA is not very stable and I have seen many problems with this. Simply change router setting to be configured with WEP and use a good strong password in hex 0-9 and a-f . WPA is horrible any way, and who the heck is gonna sit out side your home to hack it? It is not a WIN 7 problem but more like aging encryption.
Feb 07, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Making my emachines D620 wireless
when you installed the driver for the usb did you select your usb device model ? some drivers are written for usb devices AND for wireless cards (=pcmcia) and at the begining of the instalation they ask: please tell me do you have usb or pcmcia ? or they might ask you (for example) to select the right model.
now if you have "usb" but you selected "wireless card" then at the end it will try to locate a wireless card.
if this is not the case then probably your usb is not working ok - you should try it on another laptop (or pc) and then have it changed at the shop you bought it...
the driver does not recognize the device because
Oct 10, 2009 | eMachines eMD620-5133 Notebook
Can't seem to print thru wireless network anymore.
Follow the instructions in this document for setting up your printer in a wireless environment.
Aug 31, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
Jul 14, 2009 | Acer Aspire One A150-1672 Notebook
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
How to connect to wireless network using vista with SSID disabled
Normal 0 On your laptop, go into the “Manage Network Connections” and delete your network. On you router, disable the SSID. In the “Manage Network Connection” click the add connection button and enter the information about you network manually. Vista will tell you that connecting to a network that doesn’t broadcast it’s SSID is less secure and will ask you to verify. After that it will connect just fine.
The reason its less secure is because your computer will ask everything it can if its xyz network and someone with not-so-good intentions could say that its xyz network and you would connect to a insecure network and all the info that you pass on that network could be intercepted. Choose your poison I guess.
Good luck;
Eryk V.
Mar 18, 2009 | Linksys Wireless-G Broadband Router
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
HP Pavillion Dv 9000 stopped recognizing wireless networks.
make sure ya have a VISTA compatible Driver for ya wifi ... go to manufactures web site and DL latest one for VISTA..
Remove and reinstall most up to date driver... then use ya connection program to set it up.
Jun 23, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
605 people viewed this question
Alun Cox
David Payne
David Payne
