Question about Tablets & eReaders
Nexus 7 wont turn on
My nexus 7 started taking longer to start and now not at all and dosent show any thing when the charger is plugged in I tried the hard reset and nothing and then tried the unplug the battery for 15 seconds and nothing it is about 16 months old could it be the battery itself
    Master:
  • 496 Answers
It could be the battery, have you tried another charger? Perhaps a more powerful charger? If not take to a reputable repair shop
Posted on Apr 19, 2014
2 Suggested Answers
  • 7 Answers
SOURCE: Nexus 7 wont turn on for longer than a second, then it says powering off.
Charge your nexus using the ASUS wall charger that came with your nexus.
Once you connect your Nexus to the wall, just push the power button once (do not hold). A battery animation should appear showing that the tablet is charging. Let it sit for a while, then power it up.
If you suspect it's a hardware problem and if you feel comfortable opening up your device, please let me know so I can give you a step by step walk through to figure out what exactly is going on with your device.
Posted on Apr 06, 2013
Google support
Is this after serveral power-off and power-on attempts?
If so, you may need to reset it to factory defaults by entering "recovery mode".
Google "nexus 7 recovery mode" and follow the options within. All data on your nexus 7 will be lost.
Dec 06, 2013 | ASUS Google Nexus 7
Googe nexus 7 will nt charge
If you feel comfortable you could take it apart and re-solder the charge port. Most tablets are not that hard to take apart. You really just need some plastic pry bars and small screw drivers
Nov 20, 2013 | ASUS 32GB Google Nexus 7" Tablet with...
My asus tablet wont turn on
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty.
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.34689589-4d42-4ff6-a950-042de234083f.png
Nov 04, 2013 | ASUS Tablets & eReaders
Apr 06, 2013 | Google Nexus 7
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 is not turning on anymore. It's been charging for days. Any ideas?
However this will void your warranty. Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.
Mar 06, 2013 | Tablets & eReaders
My google nexus 7 wont turn on
Sorry to hear/read this.
First, try get a new charger and plug your Google nexus 7. Suspect a dead battery with no charge left on it.
Otherwise, confirm your charger isn't just lighting up whereas it isn't delivering any charge current to your device.
Next to try if your ac charger is confirmed good is to attempt replacing the battery; at the store, have them insert a compatible/similar battery and then try power on your device.
NOTE:
New batteries at the point of purchase have some charge on them; sufficient to power on your device.
Device not power on, DON'T PURCHASE NEW BATTERY. Obviously, you don't have a power/battery problem.
Device power on, then you either have a battery that has failed or that your device's charging port needs to be serviced or repaired.
Please post update/feedback asap. Thanks
Oct 10, 2017 | ASUS Google Nexus 7 Tablet
Nexus 7 will not completely turn on
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.17d253bb-4ba9-4ee2-99ca-91507603cc78.png
Dec 05, 2012 | ASUS Google Nexus 7 Tablet
Tablets & eReaders Logo
90 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
