Question about Datamax DMX-I-4208 Label Printer
Datamax + printer status - Datamax DMX-I-4208 Label Printer
2 Suggested Answers
  • 37 Answers
SOURCE: Datamax M-4208 label printer is not printing. It
probably a bad or very dirty sensor - use compressed air to blow out the sensors (look in the user manual to locate the sensors)
Posted on Dec 09, 2009
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Dmx-4204 and zpl
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Jul 23, 2013 | Datamax E-CLASS DMX-E-4204 Label Printer
Zpl emulation with datamax i-4208
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
Datamax DMX E4203 Printer driver
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Aug 19, 2012 | Datamax DMX E4203 Printer
Datamax M-4208 label printer is not printing. It is showing paused status
Dec 08, 2009 | Datamax M-4208 Thermal Label Printer
Vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
Apr 10, 2009 | Epson Printer
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
DATAMAX PRINTER
Hi
Its worth checking that you are using the latest drivers. You should be able to get these from the Datamax website. Also check the printer set up, gap sensor etc. Also check the media is loaded correctly. Hope this helps. Regards Stu www.labelzone.co.uk
Jun 19, 2008 | Datamax DMX E4203 Printer
My datamax prodigy plus wont print out a word doucment
You need to download the Windows Drivers from Datamax Website, you can then use the printer with all Windows based applications
Apr 13, 2008 | Datamax Prodigy Plus Thermal Printer
Datamax DMX-I-4208 Label Printer Logo
14 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
