Question about Zebra P110i Led Card Printer
Mechanical Error! Check for evidence of card jam.
Mechanical error
Mechanical error can be a lot of things, you have to take the printer to a tech so he can open and see if orange ribbon its lose and need to be replaced.
Jan 20, 2014 | Zebra P120i Thermal Card Printer
My zipra pi20 disply Mechanical error , can you help me to solve this problem
Please check you don't have a card jam.You should go to Driver(Start/Printer and Drivers). Then go to tools, select eject card. If you have a card stacked it will eject it or try to move. Don't try to take it out with your hand.
Apr 01, 2013 | Zebra P120i Thermal Card Printer
Check toner cartridge
The error 200.16 on a Lexmark X644E indicates that the main drive motor is not working due to high mechanical load due to paper jam or bind. The recommended actions are:
- Make sure paper path is clear.
- Check motor to system card connections.
- Replace transport motor.
I suggest you contact our Technical Support Hotline on 1-800-539-6275.
Jul 26, 2012 | Lexmark X644e Laser Printer
I have a Samsung CLX6210FX. I get this error Paper Jam 2 Check Inside. I check the paper tray and the toner door but could not find where the paper jam is. Please help
This can be very difficult to find especially if they are small pieces. If you remove the toner cartridge and with a flashlight look all around for any evidence of paper. Also check thoroughly all the doors that will open and all around the rollers. Lastly and this is difficult is the fuser in the very back of the printer. These rollers are extremely hot and sometimes when the fuser goes bad, it will keep the paper in the fuser causing the jam. On the menu you will probably see error codes as well. Hope this helps.
Mar 19, 2011 | Samsung CLX-6210FX Laser Printer
Paper jam lights despite no evidence of a jam.
prior to the issue ,basically is your paper path sensor .1)firstly try to check all the sensor lever ,it must be at home position .i guess one of the paper path sensor lever activated paper present.this usually happen when removing jam paper incorrectly causes the lever sensor spring came off .2)it can also be the clutch and solonoid rotation timing issue.good luck ,pls rate me if u satisfy wih my clarification.!!!!!!!
Sep 08, 2009 | Canon PC-735 Copier
There is an error massage: Paper jammed - clear paper jam and press Ok I make this 2 steps but there is no result, again the same massage.
Turn the printer off, push anything mechanical that you move, push with reasonable force. It could be a mechanical jam rather than paper.
Jul 02, 2009 | Canon MX300 Office All-In-One Printer
MECHANICAL ERROR
Did you check if any card is stuck inside. Run a cleaning card. For that you need to press the button for 3 secs and it will start the cleaning cycle. Feed the cleaning card in the feeder and later from output.
Oct 31, 2008 | Zebra P330i Thermal Card Printer
Paper jam 71
Paper jam 71 is an error that occurs when a driver on the controller board (IC-28) begins to wear out, or the timing gets thrown off. This causes one paper feed motor to drag the other one. This error is normally accompanied by a loud grinding noise because of this. Kodak's newest firmware version is supposed to fix the problem. If that has no effect then the fix is to replaced the controller board.
Good luck.
Jul 07, 2008 | Kodak 6800 Thermal Photo Printer
Paper jam
well part inside your product (paper handler/sensor) got damaged. must be serviced / non-user serviceable part.
Jan 22, 2008 | Epson 1000 ICS All-In-One InkJet Printer
Zebra P110i Led Card Printer Logo
173 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
