Question about Logitech QuickCam Express 5-Pack Personal Web Camera
How difficult is it to put in a new USB root hub in an EMachine W3622
  • manniep Jun 19, 2009
    Thank you very much. I will try that
  • 3,600 Answers
Quite easy buy one from fry's online a 4 port pci slot type and remove the two screws on one side pull the safety plate off the PCI slot off the case and install the PCI card into the mother board and install screw and run the DVD to make the usb ports work and pt lid back on and your set to go.
Posted on Jun 19, 2009
  • Bruce Hathcock Jun 19, 2009
    if you havea problem let me know and I will walk you threw it.
  • 23 Answers
Open up your EMachine and make sure you have an open PCI slot. Then go to best buy and grab a 4 port USB 2.0 PCI Card... they cost about 10-20 bucks;)
Posted on Jul 07, 2009
Usb mouse not working
Solution is to re-install USB Root HUB > Make sure you disconnect all USB devices before you follow these directions. Use a PCI mouse and/or Keyboard to do the following. You may try using a USB mouse, but often times you'll uninstall your mouse's USB Root HUB before you completely uninstall all the other USB Root HUBs making your mouse useless. Follow the steps in the link over and over until all USB Root Hubs are uninstalled. Restart your PC and then slowly add one USB device at a time.
Side notes: Keep in mind if you have way too many USB devices you will need a Powered USB HUB. You can buy them cheap, and they are worth it. Often times folks plug more USB devices than their motherboard/power supply can handle or they rotate like 40 devices on one PC. Rotating is OK, but you might want to follow these steps to make sure your PCs USB is working OK.
The link:
DriverFinder We Make Drivers Work for YouPC Driver Tips Tweaks to...
Jan 17, 2014 | ASUS G50 G50v G50v-x1 G50vt-x5 Series...
Tip
USB,Ipod and external hard drive not recognized in laptop,desktop.
Hi there,<br /> Follow this steps,if it is not working then post back i have 3 more steps left.<br /> <ol> <li>Click Start</b>, click Run</b>, type <span>Devmgmt.msc</span>, and then click OK</b>. The Device Manager</b> window opens. <li>Expand Universal Serial Bus controllers</b>. <li>Right-click a USB Root Hub in the list, and then click Properties</b>. The USB Root Hub Properties</b> dialog box is displayed. <li>Click the Power Management</b> tab. <li>Click to clear the Allow the computer to turn off this device to save power</b> check box, and then click OK</b>. <li>Repeat steps 3 through 6 for each USB Root Hub in the list. <li>On the Action</b> menu, click Scan for hardware changes</b>. <br /><br />Windows XP recognizes the new device. <li>Close the Device Manager</b> window.</li></ol> Hope this helps.<br /> Cheers!!
on Jan 05, 2011 | Computers & Internet
Tip
USB DEVICE DOES NOT recognize
Issue:: USB DEVICE DOES NOT recognize
___________________________________
Manual Troubleshooting for this issue::
-Open device manager
-Right Click on USB Root Hub
-Choose Properties >>Selet Power Management
-Remove the Tick Mark Before "Allow the computer to turn off the power if device is not in use..."
-Do the same for all USB ROOT HUB
-Then Uninstall all USB ROOT HUB
-Restart your computer , USB device will be working.
on Jun 21, 2010 | Computers & Internet
Dear Sir, Have Dell laptop Inspiron 1525 with Xp loaded....but external mouse is not working with my system but the USB port are working, Sir i need your assistant how do i do with it. Pls HELP...
You will uninstall all the usb universal root hub , and to do follow all the steep.
R- click on My com>Properties>Hardware >Device manager>Scrol the mouse down for select usbhub controller . Now you will uninstall all the usb and restart the raptop again.
If your problem will same ,change the usb MOUSE .
Think it is defected.
Hope it will help you.
Dec 31, 2010 | Computers & Internet
USB Hubs won't install
Please install the usb hub power surge patch from www.dell.com/support
Aug 24, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
Tip
Resolving intermittent Windows USB device issues
PROBLEM: USB Devices (Both internal and external) work intermittently.
DISCUSSION: Issue is caused by Windows power management disabling the USB Root Hub to save power (This option is on BY DEFAULT in all Windows installations)
RESOLUTION: Open Device Manager, scroll down to the USB Root Hubs Listings (There may be as few as two most I've seen is 7) Right click each hub, select Properties on the drop down menu, then click the POWER MANAGEMENT tab. There you will find a check box to allow windows to turn off this device to save power. Uncheck the box and close the window, repeat on remaining USB Root Hubs, then reboot.
This will resolve most intermittent USB device issues.
on Dec 03, 2009 | Computers & Internet
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Hi there I just brought a mikomi gp-311a 4 port usb hub for my aspire 5315 laptop (1gb). After root hub installed sucessfully,i added my other usb devices into the hub and it is not regonising any of my...
The problem is that some usb hub devices are not powered enough to recognise peripherals, i always recommend buying a mains powered usb hub as the pc's supply can find it difficult to power the usb ports enough as well as powering other components in your pc.
Sep 12, 2008 | Computers & Internet
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
When i put my headset to charge it stops charging after 5 seconds
if you are using the USB port on the computer to charge it, it may be an issue of your computer going into "Power Save" mode and shutting down the USB power. I found this by google searching "usb power save mode"... Possible Fix: 1. Click on "Start" and then right-click on "My Computer." 2. Click on "Properties" and then on the "Hardware" tab. 3. Half-way down on the right, click on "Device Manager." 4. Click the "plus" sign in front of "Universal Serial Bus Controllers." 5. Double-Click on the first "USB Root Hub" (not USB 2.0 Root Hub). 6. Click on the "Power Management" tab. 7. Uncheck the box that says "Allow the computer to turn off this device to save power." 8. Click "OK" and repeat for all other "USB Root Hubs." 9. Finally, close all and go back to the desktop.
Jun 07, 2007 | Motorola Mobility H700 Wireless Headset
Logitech QuickCam Express 5-Pack Personal Web Camera Logo
164 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
