SC-1031W is a tablet made by Smartab. To hard reset the tablet, you can follow these steps:
Turn off the tablet by pressing and holding the power button for a few seconds.
Press and hold the volume up button, and then press and hold the power button.
Keep both buttons pressed until the Smartab logo appears on the screen, and then release the power button while continuing to hold the volume up button.
When the Android logo appears, release the volume up button.
Use the volume down button to highlight "wipe data/factory reset" and press the power button to select it.
Use the volume down button to highlight "Yes -- delete all user data" and press the power button to select it.
Wait for the reset process to complete, and then use the power button to select "reboot system now" to restart the tablet.
Please note that performing a hard reset will erase all data on the tablet, so make sure to backup any important data before proceeding.
press and hold down the volume down button and power button when the screen comes on release your finger off the volume down button then press the volume down button again
will go to recovery mode
go to wipe data by using the volume down button highlight wipe data press power button to ok it
then go down to yes with the volume down button highlight yes then press power button to ok it will reset it
then it will go back to the writing go to reboot highlight reboot then press power to ok it
Warning! All data will be lost after hard reset.Please make backup first.
1.Power off your phone
2.Press together volume up + home button + power button until you will se Samsung logo on the screen
3.Select with volume buttons "wipe data/factory reset" and press power button to confirm
4.Select "yes" and press power button to confirm
5.Wait until format is complete
7.Press power to confirm "reboot"
8.Wait until the phone restarts
That's it!
- See more at: http://factory-reset.blogspot.ro/2013/11/samsung-galaxy-s3-4g-i9305-hard-reset.html#sthash.IRpj0Oyt.dpuf
Here`s how to hard reset you Spark Tv
1. Turn off the your Cherry mobile Spark
2. Press power button, Volume down and home button at the same time.
3, Wait for a Spark TV logo then release power buttons and continue holding Volume down and Home.
4. Scroll down and select wipe data then press home button
5. Select reboot and your phone will be unlock but all files in the internal storage will be deleted.
or try this
SPARK TV cherry mobile HARD RESET too many patterns attempt solution
POWER ON + VOLUME DOWN BUTTON press together in 20 seconds or until the Android system recovery <3e> appeared
Press volume down to wipe data/factory reset then press power on
Press volume down Yes -- delete all user data then press power on
Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
Now, press the 'volume +' button to enter into the recovery mode.
This will make a Android icon appears on screen, press power button.
This will get you the menu options, use the volume up and down button to choose the option.
To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
Turn Off your device
Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
If you want to hard reset your smartphone, you should select the recovery mode.
To navigate it, you can use volume up and down.
To select an option, you must press the Menu button.
After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
Press and Hold Volume Down + Power Key for 20-30 Seconds.
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
When the LED lights in green, press the Stop/Reset button 4 times
