Question about LG B2100. Cellular Phone
How do i removelg simlock code-1 - LG B2100. Cellular Phone
Sim lock code foe gt-b3210
Just go to the link below and select your model no and place order to get the sim unlock pin
https://www.unlockninja.com/unlock-samsung+phone
Feb 26, 2018 | Cell Phones
Tip
Lg secret tricks
LG all models test mode:
Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*
on Mar 08, 2010 | Cell Phones
I really need a simlock unlock code for a huawei u8150
You can get the unlock codes for your Huawei u8150 from your service provider or from reliable online sites like unlocking4u.com .You can get the codes by specifying Your phone's manufacture, model,country and network!The steps to unlock is simple here and the codes are affordable!!!!
May 27, 2012 | Cell Phones
How to remove my simlock in my phone s3653 i forgot
Did you forgot the procedure to SIMLOCK you Samsung S3653 or did you forgot your phone lock code?? if you want to simlock your mobile then you can do it by unlock codes and for codes try Simpleunlocking and get your mobile unlocked from network and if you want security code try to reset your mobile..
Dec 07, 2011 | Samsung S3653 Cell Phone
UNLOCK SIMLOCK SAMSUNG GT-E1080I
Sasmsung E1080T guru and Samsung E1080I are same Phone Only...You can unlock the sim lock using the unlock code,You can get the Unlock code for samsung E1080 T Guru from here Onlinegsmunlock.com and Unlock it from Sim Network Lock.
Nov 14, 2011 | Cell Phones
My Samsung GT-E1086 is simlocked. How can I remove the simlocked?
This has happened to me before. There are only two things you can do:1. If you have the card that your SIM card came in then you can plug in one of the codes to unlock your card.2. If not, then you have to go into your carrier store and have them give you a new SIM card.
Aug 25, 2011 | Cell Phones
I forgot my simlock code of my Samsung GT-B3210. I can only remember my phone lock code. So the problem is that I can only use my own simcard for the phone. Without my simlock code I can't use any...
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jul 25, 2011 | Cell Phones
Help openline..or remove sim lock for Nokia N73
removing a nokia simlock.. did u simlock it yourself or you forgot the simlock code. any way if you still cant get through with the simlock.. i will sugetst you hard format your nokia through this procedure...have u tried the hard formating.. the hard formating will remove the code and activate the nokia default code for you.. switch off ur fone, then press and hold *+3+(send key) 3-5 mins without removing ur hands,.. then ask someone to help you switch on the fone still dont remove your hands off the key till the fone restats.. this shuld help.. thanks
Dec 21, 2008 | Nokia N73 Cellular Phone
SIM LOCK CODE
Simlock code to unlock my simlock
Nov 20, 2007 | Samsung SGH-D900 Cellular Phone
LG B2100. Cellular Phone Logo
27 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
