Question about APC Smart-UPS VT 30kVA UPS System
We have 30KVA apc smart Ups VT,but its getting start ,its just start 2 seconds and shutdown.what could be the problem?
SOURCE: APC Smart-UPS 1000VA shut down and now will not power on. How do I troubleshoot?
Hello Chris,
I have a similar unit and there is a fuse inside that can blow. Mine did. It worked again after replacing the fuse.
Another option...check the battery connections.
Another option...are the batteries getting old? If so, when they won't reach a certain level of charge the unit will not power on.
Finally, make sure you don't have a blow fuse or popped circuit braker in your home.
Hope this helps?
Charlie
Posted on Nov 23, 2007
  • 55 Answers
SOURCE: APC Smart UPS 1500 will not start.
It could be that the cable to the front-panel got damaged during the battery replacement.  After all these years you would think APC would improve that aspect of their design.  All I can suggest is inspecting the cable and where it connects to the front panel.
Posted on Apr 26, 2009
SOURCE: smart ups 1500 apc making loud noise
tighten the screwa on the body
Posted on Jun 10, 2009
SOURCE: APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Posted on Jun 17, 2009
jvpacoin
  • 91 Answers
SOURCE: apc smart ups su1000, su750i and sua700inet circuit diagram
you mean you need a circuit diagram for the following APC unit? i dont think so if you can get unless theres one MF from APC manufacturing or service center that can give it or sell it to you. beacuse as far as i am concerned it is punishable by law to sell or to give copy of all circuit diagram of APC products. Good luck
Posted on Aug 14, 2009
APC Smart VT 30KVA UPS cannot sustain power after power failure
ups units run a computer directly from mains power and from a battery when mains power is cut.
some run the computer through the battery at all times and so use the battery as a surge protection
points to check on your unit
is the by pass system being damaged in the surge protection section
is this requiring the batteries to provide power but not being charged at the same time
Is the power consumption exceeding the battery rating ( pc, printer, monitor , modem etc exceeding the out put of the ups
Apr 27, 2015 | American Power Conversion Corp...
Apc smart ups vt - no mains detection
be more precise
more info needed. what did you do. how did U startup the unit?
Mar 14, 2015 | APC Smart-UPS VT (SUVTP30KH3B4S) UPS...
Why does an APC Smartups 30kva have high battery temperature alarm?
UPS should be located in an environment where the temp should not exceed 25 degrees Centigrade, or you may have a damaged fan (inside the UPS, or the temperature sensor is defective.
Jun 09, 2014 | APC SmartUPS VT 30kVA Rackmountable UPS ...
Smart-ups VT 30kva system not getting start?
Ramesh,
There are multiple reasons why this is happening. Give me a call, reply here, or email me and I'll be glad to help.
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 19, 2014 | Computers & Internet
30kva apc ups VT is nor getting On?
Try holding the "on" button for a few seconds until magnetic relay is on.
Sometimes flat(dead) batteries will stop UPS on
Apr 19, 2014 | APC Smart-UPS 2200XL (APCSMART2200XL) UPS...
Ramesh,
See my answer to your previous post.
Quote:
" Ramesh,
There are multiple reasons why this is happening. Give me a call, reply here, or email me and I'll be glad to help."
How to find out damaged battery unit in 30kva apc smart ups VT?
pull them out, examine each one for cracks, bulging, leaking, then check the voltage. Should be around 12.25v fully charged.
Apr 19, 2014 | APC Smart-UPS 1500VA Shipboard...
Smart UPS VT 10KVA fault "Mains Not Available. Input Freq/Volt Out of Range". All phases input and output giving the expected voltages 240V and frequency OK at 50Hz.
Sounds like you hooked up the input to the UPS on the bypass. Either way either way your input is not there. Also make sure you configure the UPS prior to placing online.
Oct 04, 2013 | APC Smart-UPS VT 10kVA - SUVT10KH2B2S UPS...
APC 10kva UPS SUVTP10KH1B2S is not turning on
check the battery bank, and the battery must be in good condition
May 13, 2013 | APC Smart-UPS VT SUVTP10KH1B2S UPS System
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
APC Smart-UPS VT 30kVA UPS System Logo
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
