Question about Neff U1452 Double circotherm plus Electric Oven
Neff oven fan not turning and element blown. Is the motor bad as well?
  • robert_webbi Jun 19, 2009
    The wasp nest was very funny....
    Its just that most posts say "my fan is turning but my oven does not heat"
    Well I know my oven does not heat as the element is blown but also the motor does not turn when the power is on.
    Do you need the element to work before the fan will turn?
    The fan spins free when turned by hand.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
It might also be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
  • 3,600 Answers
If it is mounted in a wall that goes outside you may have a wasp nest built up in the fan cage, replace the element first and see if the fan spins freely if it does then the fan may be bad as well
Posted on Jun 19, 2009
  • Bruce Hathcock Jun 19, 2009
    if the heating coil is shorted it will cause the fan not to function as thats where it gets it's feed for power.
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Neff fan oven dead. Where do I look next? I've
this could all so be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
Dec 17, 2009 | Neff U1721 Double circotherm Electric Oven
No heat on bottom oven. fan running but not heating up
Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Tip
Common heating faults with Neff B1428 single oven
on Jan 19, 2010 | Neff B1428 Nostalgic Single circotherm...
Tip
Common heating faults with Neff U1421 Double oven,
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
Tip
Neff U1452 Double oven Common heating faults,
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
Tip
Common heating faults with Neff U1661 Double oven
on Jan 19, 2010 | Neff U1661 Double circotherm super...
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Tip
Common Heating faults Neff U1721 Electric Oven
on Jan 19, 2010 | Neff U1721 Double circotherm Electric Oven
Neff U1452 Double circotherm plus Electric Oven Logo
612 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
