Question about APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System
How to find out damaged battery unit in 30kva apc smart ups VT?
    Scholar:
    New Friend:
  • 69 Answers
Pull them out, examine each one for cracks, bulging, leaking, then check the voltage. Should be around 12.25v fully charged.
Posted on Nov 28, 2014
IB4G2008
  • 3587 Answers
SOURCE: APC Smart-UPS 1500VA
yeppers...those APC units sometimes kick the monitoring software. sometimes you need to unhook the connection cables(like a reset) so that the firmware can 'unlock' which can cause that christmas tree effect on the panel lights.
Posted on Feb 06, 2008
  • 37 Answers
SOURCE: APC Smart UPS 3000VA - Dead UPS
ok how long you brought the ups and how long you had not start the the ups usaully ups is power dead change the battery and try to power up it should work be sure that all connection is connect properly before power up the ups.. if the ups doest work that will be the mainboard problem you hav to call for vedor to repair the unit.. yes these fuse for the ups but it unlikely to be blown so should worry of the fuse it self.. change of battery come with different spefc for the ups.. eg su3000rmi3u, sua3000rmi3u, su3000rmxl3u --- battery replacement is 8 pcs of 12v 7ah. sua3000rmi2u-- 6 pcs of 12v 7ah or 8 pcs 12v 5ah. su3000rminet-- 4 pcs 12v 17ah,
Posted on Mar 28, 2009
JaxPlanet
  • 921 Answers
SOURCE: APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Posted on Aug 18, 2009
  • 355 Answers
SOURCE: All battery charge lights flash simultaneously.
THIS seems the be the answer to your question. Hope this helps
Posted on Apr 29, 2010
SOURCE: smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Posted on Aug 26, 2010
APC Smart VT 30KVA UPS cannot sustain power after power failure
ups units run a computer directly from mains power and from a battery when mains power is cut.
some run the computer through the battery at all times and so use the battery as a surge protection
points to check on your unit
is the by pass system being damaged in the surge protection section
is this requiring the batteries to provide power but not being charged at the same time
Is the power consumption exceeding the battery rating ( pc, printer, monitor , modem etc exceeding the out put of the ups
Apr 27, 2015 | American Power Conversion Corp...
Apc smart ups vt - no mains detection
be more precise
more info needed. what did you do. how did U startup the unit?
Mar 14, 2015 | APC Smart-UPS VT (SUVTP30KH3B4S) UPS...
Why does an APC Smartups 30kva have high battery temperature alarm?
UPS should be located in an environment where the temp should not exceed 25 degrees Centigrade, or you may have a damaged fan (inside the UPS, or the temperature sensor is defective.
Jun 09, 2014 | APC SmartUPS VT 30kVA Rackmountable UPS ...
Smart-ups VT 30kva system not getting start?
Ramesh,
There are multiple reasons why this is happening. Give me a call, reply here, or email me and I'll be glad to help.
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 19, 2014 | Computers & Internet
30kva apc ups VT is nor getting On?
Try holding the "on" button for a few seconds until magnetic relay is on.
Sometimes flat(dead) batteries will stop UPS on
Apr 19, 2014 | APC Smart-UPS 2200XL (APCSMART2200XL) UPS...
Ramesh,
See my answer to your previous post.
Quote:
" Ramesh,
There are multiple reasons why this is happening. Give me a call, reply here, or email me and I'll be glad to help."
Smart UPS VT 10KVA fault "Mains Not Available. Input Freq/Volt Out of Range". All phases input and output giving the expected voltages 240V and frequency OK at 50Hz.
Sounds like you hooked up the input to the UPS on the bypass. Either way either way your input is not there. Also make sure you configure the UPS prior to placing online.
Oct 04, 2013 | APC Smart-UPS VT 10kVA - SUVT10KH2B2S UPS...
APC 10kva UPS SUVTP10KH1B2S is not turning on
check the battery bank, and the battery must be in good condition
May 13, 2013 | APC Smart-UPS VT SUVTP10KH1B2S UPS System
How to extract batteries from an APC Smart UPS 1400
greg milton, Hi, Did you get the top cover off of the "1400" battery back-up? How old were the batteries in the unit? My APC 1250 has two 12v 18ah units inside. It's best to replace batteries every 3 to 5 years! 12fixlouie
Aug 20, 2010 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
It is possible to attach the 120 AH battery with APC 1000 va UPS
YES IT IS POSSIBLE TO CONNECT A LARGER BATTER TO THE APC UPS. IT WILL ONLY NEED MORE TIME TO CHARGE THE BATTERY.
Apr 10, 2010 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System Logo
79 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
