Question about Kyocera Mita Office Equipment & Supplies
Kyocera km 5035 error 210 - Kyocera Mita Office Equipment & Supplies
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
n25an
  • 622 Answers
SOURCE: Kyocera-Mita going offline
it sounds like there is an ip conflict... you may need to reserve an ip address just for the copier or failing that change your copiers ip address to one below the ip range... if it still has problems then I would check the network cables.... and see if you get any error codes... copier can go offline if 1. the print card is loose... bad mounting socket on the main board... ip conflict... someone else has the ip address... poor network traffic... the signals over the network cables are degrading too fast... so the copier gets a corrupt file or unfinished file and bombs out... power surge... this causes firmware corruption and the thing just starts shooting wierd error codes... I think I have given you enough to think about...
Posted on Dec 07, 2009
shawn38
  • 200 Answers
SOURCE: Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
Posted on Feb 19, 2010
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
KM 5035 0630 FAULT CODE
Fuser failure , enter service and reset fuser error.
Jul 15, 2014 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera km 5035 error c2500
Paper feed motor problem.
Ensure that all cassettes are correctly loaded with paper.
Ensure that by removing the paper cassettes no paper is jammed behind them/in the copier.
press 1087 1087 on the key pad,then 906 then start,then execute then start.
Press 001 to exit.
Aug 14, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
C7400 error kyocera km 5035
Error C7400 on Kyocera km 5035 is Image formation unit problem or connector
Hope this will help
Feb 14, 2012 | Kyocera Mita KM-5035 Printer
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Dec 10, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Feb 18, 2010 | Kyocera Mita KM-5035 Printer
0630 Fault code on KM 5035
you have a defective main PCB. you should contact your nearest service agent
Mar 13, 2009 | Kyocera Mita KM-5035 Printer
42 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
