Question about Sony Kds-r60xbr2 60" Xbr Rear Projection HDTV
My sony sxrd xbr 60 in tv begins to tick and grow in intensity before shutting off.
Bought a replacement lamp when tv warned of lemp life nearing end. the television begins to tick after being on for about 15 minutes and grows in intensity before shutting off. What can i do??
  • Connor Folks
    Connor Folks Apr 19, 2014
    it proceeds to blink red 4 times. have replaced the lamp twice in 5 months so lamp is not the problem
    Problem Solver:
  • 6 Answers
Ok I know there was a recall on some Sony tv's regarding the optic block.. they were temporarily fixing them and it would not be a permanent fix so I ended up with a new tv, I would ck and see if your model was one of them. Good luck..
Posted on Apr 22, 2014
  • 4234 Answers
SOURCE: Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: At start up a sign reads, Projection lamp nearing end of life
Might also want to try amazon.com. Sony is 199
Amazon was around 150.
And you can easily do this yourself.
Theres a little door at the right side if your looking at the front. (left if your looking at the rear) Open that up and youll see another door that has a little latch on it. turn it about a 1/4 turn to the left and it will release that door and pull it straight out. then there is the bulb, and that has a little wire ring that is the release. Pull that up and out.
Posted on Apr 01, 2009
  • 1015 Answers
SOURCE: sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
Posted on Jan 09, 2010
milkburp
  • 416 Answers
SOURCE: Just replaced the projection lamp but the tv still
Use the "Lamp Replacement" option in the Setup menu to reset the timer.
Posted on Mar 13, 2010
  • 125 Answers
SOURCE: My KDS-60A2020 SXRD Sony TV has a green tint to
Green Tinit in picture is the first sign of Bad Light Engine
UED 1-800-648-6657
Posted on Oct 23, 2010
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS60R2000 Bravia SXRD Full HD - No picture after its switched on. Green light blinking but no picture. Since it was bought (new about 4 years ago) it would occasionly just "switch off" by...
It is time for new lamp in tv as existing has reached on end of its working life.
Replace lamp in tv to fix the problem, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 05, 2010 | Sony KDSR50XBR1 50" Projection HDTV
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a sony tv, model number KDF60WF655... i turn the tv on and it turns on for about 1 min then turns off, the green light flashes several times then turns itself on again. the process keeps repeating...
Replace lamp in tv as this symptom shows existing lamp is near to end of its working hours life span and need to be replaced.
Lamp replacement procedure is easy and would be written in user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a sony xbr lcd projection tv . it goes on and off all the time . like every two min . and the standby light comes on. model KF-50XBR800
Its symptom of weak lamp that reaches to end of its working hours life span. If lamp has not been replaced in last 2-3 years then replace it to fix tv problem.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Jul 16, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Power keeps going on and off
Model number posted in question that is KDF-60SX955 shows it is Sony dlp tv, if tv shuts down and turns On itself then reason is weak lamp that is near to end of its working life and need to be replaced to fix this issue.
Lamp replacement procedure is written in user manual and its easy. Please buy Sony original lamp for good quality picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony, SXRD Projection TVKDS-55A2000 Was working fine, then picture vanished. We have red blinking light on front, indicating lamp. I presume that lamp need to be replaced, but TV has only been operating...
Same thing happened on mine, you need to replace the bulb, on our TV I have 2 kids so the TV was always on but lasted 2 and a half years which impressed the warranty people. From what I have heard the average life is about 2 years. I have the same SXRD TV.
Aug 10, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Need instructons for changing Sony SXRD XL5300 lamp.
If you instructions manual you can download from Sony Web
Cheers
Dec 10, 2008 | Office Equipment & Supplies
Sony Kds-r60xbr2 60" Xbr Rear Projection HDTV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
