Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have A 52" phillips projection tv That has a bad case of double vision. The picture looks like what happens when you drink way too much. I tried setting the convergence and it helped a little. Any ideas?
  • tracys73 Jun 20, 2009
    Not to sound stupid but where exactly are these fuses located? I have the back off the TV and cannot locate them.
  • 110 Answers
Replace Fuse 1405 and 1407 using Part# 242208610965 5 AMP (LT)
Replace Fuse 1007 Part# 242208610783 2 AMP.
Posted on Jun 19, 2009
  • TOM2-TOM2
    TOM2-TOM2 Jun 19, 2009
    # NOTE - If this info was helpful to anyone please click on yes!
  • TOM2-TOM2
    TOM2-TOM2 Jun 21, 2009
    1405 is off pin# 17 of switch mode transformer
    1407 if off pin# 18 of switch mode transformer
    1007 if off pin #4 of IC1676 the +32v line.
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
My RCA projection TV is showing double vision
You can get the STK730-130 convergence IC at the following link which should take care of that issue. Its 24.00
http://servicemanuals.vstore.ca/product_info.php/pName/stk730130/cName/convergence-ics
Jul 12, 2009 | RCA P52920BL 52" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Tv problem
It sounds like your convergence is going bad.. this is pricey in older tv's. Look inside (but be careful) and see if there are some really big heatsinks with a IC mounted on each one. they should have a number like STK???-???. These are the convergence IC'S- change them, and you should be ok (IF your set uses the STK style IC's)
hope this helps.
Jul 05, 2008 | RCA D52W19 52" Rear Projection Television
Help with my double vision
What model is your tv? Panasonics have a 'self-alignment' system in the menu, or a manual alignment that the menu will actually walk you through. Other System's will be able to do that also, such as Hitachi.
Aug 24, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
177 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
