Question about Acer TravelMate 2300 Notebook
Cannot connect acer aspire one to projector. it's first detected when netbook is booting up but the connection dispappears (no input on projector) when the computer is fully on.
  • Acer Master
  • 4,806 Answers
It should be a keyboard toggle to switch display to the projector, usually Fn + F5, sometimes you have to tap the F5 key a couple of times for the display to switch over.
Good luck
Posted on Jun 19, 2009
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an Acer One netbook and tried to connect it to a projector but the normal looking lead from the projector did not seem to fit. The lead has those two wee screws at the side, and no place for them...
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
I need to show Powerpoint slides from my Acer Aspire One netbook. When I connect to the projector it does not work. Why?
Have you pressed Fn+F5? It commands using external monitor/ projector. Try this:
1. Connect to projector with projector in ON position
2. Restart your PC
If it won't work:
1. Restart your PC, press F8 frequently, choose "enable vga mode"
May 01, 2010 | Acer Aspire One PC Notebook
How to connect the acer aspire one to an epson projector
The Aspire One has an external VGA port so you will use that and a VGA cable to connect to the projector. You may have to press the Display mode button (typically Fn+one of the function keys with the rectangle 'display' on it) to enable the external VGA port.
Mar 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
When I connect my Acer Aspire One Netbook to my Proxima Ultralight LX1 projector it gives the ''Windows'' page and then stops projecting. It says ''Searching''
Hook up computer to projector AFTER projector is turned on. Power on.
Right click on your desktop.
Click on Graphics Options.
Click on Output To.
Click on Intel (R) Dual Display Clone.
Click on Notebook + Monitor.
Oct 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
Get my screen back after connecting a projector
Fn + F5 toggles the display output.....but when you run a projector or other device, the backlight shuts off and to turn it back on, the combination is Fn + F6.
Oct 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Problem connecting my acer aspire 5600 to a projector
First let it install this can take a minute or 2 (this goes automaticly) when this doesn't work go to your ATI control panel somewhere is a button where you can control a other monitor/projector
Oct 15, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
ACER Aspire One AOA150-1635 and Sharp XR32-X projector
you need to connect it with VGA. then enable the 2nd monitor
now you should have a wallpaper on the projector, you can drag objects to it by draging them out from the screen.
if you don't have the 2nd screen option. Then hold down the blue FN button and then tap F5 see if the picture comes, the FN + F5 will swap around with the outputs.
Feb 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
1,483 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
