Question about Cisco Interface Module Network Adapter
I have inserted NM-1E module in a 2611XM and it doesn't recognize the module. Module hardware is Ok, interface status is bring up when plug in cable.    Cisco 2611XM Router and NM-1E are compatible; running IOS: C2600-ADVIPSERVICESK9-M, Version 12.3(4)T6.     Any help/suggestions appreciated,       Leon.
  • dougperk May 11, 2010
    Can you post a copy of the show ver and show controllers?
  • 39 Answers
can you please double check using software advisor in Cisco website.
Posted on Sep 14, 2009
What is the difference between GPON B+ and C+ GPON transceiver?
B+ Module C+ Module Type One-fiber bi-directional optical module, class B+ One-fiber bi-directional optical module, class C+ Operating Wavelength Tx: 1490 nm
Rx: 1310 nm Tx: 1490 nm
Rx: 1310 nm Encapsulation Type SFP SFP Port Rate Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Minimum Output Optical Power 1.50 dBm 3.00 dBm Maximum Output Optical Power 5.00 dBm 7.00 dBm Maximum Receiver Sensitivity -28.00 dBm -32.00 dBm Optical Connector Type SC/PC SC/PC Optical Fiber Type Single-mode Single-mode Reach 20.00 km 20.00 km Overload Optical Power -8.0 dBm -12.0 dBm Extinction Ratio Huawei GPBD Board Thunder link com
Nov 02, 2016 | Computers & Internet
Dell inspiron 1501 won't boot but caps lock flashes continuosly. when i remove memory it doesn't beep
Caps lock flashing indicates faulty memory - it's a POST (Power On Self Test) before BIOS executes. When memory is removed it should indicate "no memory". Carefully re-insert the RAM memory module, check the tiny contacts inside the connector on dust. Then try again.
If there are 2 memory banks (1 one the back, the other under keyboard) remove one RAM memory module.
If capslock keeps on flashing test it with another RAM module.
Jun 30, 2011 | Dell Inspiron 1501 Notebook
My mother has a 1993 Oldsmoblile Cutlass Cierra. It's a 3.3. She had a new engine put in it last year. Now her car died yesterday. She had to have it towed home so my brother could look at it. He got...
Check for spark. My guess would be the ignition module going out, but could also be the crank sensor. The module sits under the coils. Check all coils for spark. If any coil doesn't spark, you can try replacing just that coil, but the problem may still be the module underneath. If you have a meter, run a resistance check on each coil from the terminals to ground. If the same coil that doesn't fire aslo has a different resistance, replace that coil.
If you have a meter, check the AC voltage on each of the crank sensor wires shown as compared to ground or battery positive. If the AC voltages are different on the three wires, suspect the sensor is bad, but also check the tone ring on the pulley (Fig 2 below) for any damage.
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines for how to check for spark. These are genericinstructions.
The 3.3L engine is the only one with the C 3 I system. REMOVAL and INSTALLATION C3I Module See Figure 1
  1. Disconnect the negative battery cable.
  2. Unplug the 14-way connector at the ignition module.
Fig. Fig. 1: Distributorless C 3 I coils and module system - 3.3L engine
  1. Tag and disconnect the spark plug wires at the coil assembly.
  2. Remove the nuts and washers securing the C 3 I module assembly to the bracket.
  3. Remove the 6 bolts attaching the coil assemblies to the ignition module.
To install:
  1. Install the coil assemblies to the ignition module and install the 6 attaching bolts.
  2. Install the nuts and washers attaching the assembly to the bracket.
  3. Connect the spark plug wires.
  4. Engage the 14-way connector to the module.
  5. Connect the negative battery cable, then reset the clock, radio and any other accessories.
Ignition Coil(s)
  2. Tag and disconnect the spark plug wires.
  3. Remove ignition coil attaching bolts, then the ignition coil from the module.
To install:
  1. Install the coil(s) and attaching bolts.
  2. Connect the spark plug wires.
  3. Connect the negative battery cable, then reset the clock, radio and any other accessories.
Dual Crankshaft Sensor
See Figures 2, 3 and 4
  1. Disconnect battery negative cable.
  2. Remove serpentine belt from crankshaft pulley.
  3. Raise and safely support the vehicle.
  4. Remove right front tire and wheel assembly, then the inner access cover.
  5. Remove crankshaft harmonic balancer retaining bolt and crankshaft harmonic balancer.
Fig. Fig. 2: Harmonic balancer with interrupter rings on C 3 I system
  1. Unplug the electrical connector from the sensor and remove the crankshaft sensor from the vehicle.
To install:
  1. Loosely install the crankshaft sensor on the pedestal.
Fig. Fig. 3: Dual crankshaft sensor - C 3 I system
  1. Position the sensor with the pedestal attached on special tool J-37089.
  2. Position the tool on the crankshaft.
  3. Install the bolts to hold the pedestal to the block face. Tighten to 14-28 ft. lbs. (20-40 Nm).
  4. Tighten the pedestal pinch bolt to 30-35 inch lbs. (3-4 Nm).
  5. Remove special tool J-37089.
  6. Place special tool J-37089 on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
A clearance of 0.025 inch is required on either side of the interrupter ring. Be certain to obtain the correct clearance. Failure to do so will damage the sensor. A misadjusted sensor of bent interrupter ring could cause rubbing of the sensor, resulting in potential driveability problems, such as rough idle, poor performance, or a no start condition.
  1. Install the balancer on the crankshaft and install the crankshaft balancer bolt. Tighten to 200-239 ft. lbs. (270-325 Nm).
  2. Install the inner fender shield.
  3. Install the tire and wheel assembly. Tighten to 100 ft. lbs. (140 Nm).
  4. Lower the vehicle.
  5. Install the serpentine belt.
  6. Connect the negative battery cable, then reset the clock, radio and any other accessories.
Fig. Fig. 4: Distributorless C 3 I positioning tool J-37089 for installing dual crankshaft sensor.system - 3.3L engine
May 07, 2011 | 1990 Oldsmobile Cutlass Ciera
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
Hi, The following is the spec. What is the best graphics card upgrade options without upgrading PSU? Thanks. 1 03FCY Base,Mini Tower,Configure To Order,INSP 560 $358.67 1 07GHK...
HERE is the direct link from Dell that will tell you what graphic card will go into your system. Since there are many factors involving graphics card updates this is the best place to start.
Jan 06, 2011 | Dell Inspiron 560 PC Desktop
I am looking for a spark plug wiring diagram for 1997 buick park ave 3.8 to see if the wires may be crossed.
Sometimes the coil packs are numbered from the factory --- Firing Order 1-6-5-4-3-2
Ignition Coil Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the service precautions in the beginning of this section
  2. Disconnect the spark plug wires from the coils
  3. Remove the fasteners securing the coil(s)
  4. Remove the coil(s) from the ignition control module
To Install:
  1. Install the coil(s) to the ignition module
  2. Install the coil fasteners
    • Torque to 40 in-lbs (4.5 Nm)
  3. Connect the spark plug wires to coil assemblies
Ignition Module Removal & Installation To Remove:
  2. Turn the ignition OFF
  3. Disconnect the 14-way connector from the ignition module
  4. Note the position of the spark plug wires and disconnect from the coils
  5. Remove the fasteners securing the coil(s)
  6. Remove the coils and the Ignition module from the bracket
To Install:
  1. Install the coils and the ignition module to the bracket
  2. Install the fasteners that retain the ignition coils to the ignition module
    • Torque the fasteners to 40 in-lbs (4.5 Nm)
  3. Install the nuts and washers that retain the ignition module to the bracket
    • Torque the screws to 70 in-lbs (8 Nm)
  4. Connect the spark plug wires to the coils assemblies
  5. Connect the 14-way connector to the ignition module
    • Torque the screw to 19 in-lbs (2.1 Nm)
Oct 26, 2010 | 1997 Buick Park Avenue
Nm parity check/ memory parity error the systemhas halted call hardware vendor for support
That means your memory is bad.
Replace the faulty memory module and everything will be ok.
Don't forget to rate this answer if it helps
Sep 10, 2010 | Dell Dimension 8400 PC Desktop
CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Jul 04, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Computer no recognize CD-ROM Drive
If it is a "swappable" device, then first shut-down your computer. Remove the other device that currently is installed in the drive-bay. Insert the CD-ROM drive, and restart your computer, so that it can detect the "new" hardware.
Apr 25, 2010 | Compaq 255215-001 Plug-In Module 20x...
How do I change an ignition coil on a V6 1997 Grand Am?
Removal Procedure
  1. Remove all the electrical connectors at the ignition control module.
  2. Note position of spark plug wires for installation
  3. Remove the spark plug wires from ignition coils.
  4. Remove the screws securing coil assemblies to ignition control module.
  5. Disconnect coils from ignition control module. Installation Procedure
    1. Install the coils to ignition control module.
    2. Install the screws and tighten to 4-5 Nm (36-44 lb. in.) .
    3. Install the fasteners securing assembly to engine and tighten to 8 Nm (70 lb. in.) .
    4. Install the spark plug wires as noted during removal.
    5. Install the electrical connectors to the ignition control module
  6. Hope this Helps !
Sep 30, 2009 | 1997 Pontiac Grand Am
Cisco Interface Module Network Adapter Logo
178 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
