Question about Honda Garden
Fuel Shut off valve leaks - Honda Garden
    Master:
  • 969 Answers
Replace. Leaks at clamps, cut rubber back replace clamps.
Posted on Jul 04, 2015
Have K341s engine on a welder and crank case flooded with fuel. what should I look for?
It is likely that this engine has a gravity feed fuel system such as the lawn tractor in the photo. The problem is if the needle valve sticks open, float fails to push the needle into the seat fuel will flow until the tank empties. The fuel floods the engine and leaks by the valve stem and cylinder rings filling the crank case with fuel.
What a mess and always a concern when fuel leaks. The preventative is to make sure the fuel shut off valve is closed when engine is not being used. Usually running the engine with the shut off valve will empty the carburetor of gas a good procedure to prevent the carburetor from fouling.
You must drain the oil completly and replace before running the machine.
Likely with the engine vibration the needle will operate normally. Removing the bowl and checking for contamination is recommended.
Adding a new filter and confirming the fuel shut off is working is also recommended.
2set-float-valve-needle-seat-kit-for-briggs-stratton-398188-281144-kit-font-b-5-b-o2aflg0ryfegd3pfpl5qlmia-5-5.jpg
Jun 29, 2017 | Cars & Trucks
I have a 97 grand cherokee larado and when I shut it off it won't start back up for a few mins..then it fires up...is there a kill switch on it or something else wrong possibly
No kill switch. You may have a fuel pump pressure issue, it may being losing pressure after shut down due to a faulty fuel pump check valve. Do a fuel pressure leakdown test, start the engine with a fuel pressure test gage hooked to the test port on the fuel supply rail to the fuel injectors, looks like a tire valve. Start the engine and run it and check for leaks at the pressure port to the test gage, repair as needed, once you are sure the test gage is leak free shut the engine down, if the fuel pressure bleeds down very quickly then you need to replace the fuel pump.
Apr 12, 2017 | 1997 Jeep Grand Cherokee
I have drained the fuel tank on my bike to fix a leak in the fuel line. I have put fuel in the tank but bike won't start. Do I need to bleed air from the system and if so how? Thanks.
Is there a shut off valve at the bottom of your tank? Possibly you shut it off and just forgot to open it . When you drained your tank, did you rinse out the inside with gas, to make sure the screen at top of shut off valve was not clogged. Is the shut off valve clogged? If there was grime in your tank it could have gone past the shut off valve to carburetor, causing a clog. You may have to do some cleaning, take your time. GOOD LUCK FRIEND.
Nov 28, 2014 | Tank Motorcycles
Why is my carburetor leaking fuel after I turn off my motor
It is most likely that your shut off valve is leaking (as fuel flow should be shut off with no vacuum applied to it). If the float level is okay, and it must be set very precisely at 0.413 - 0.453 inches with the carb tilted no more than 20 degrees and no less than 15 degrees, (if the float level is the problem such that the fuel supply would be too high in the float bowl and depending on how far out it is set ie how high the fuel is allowed to rise in the float bowl it would likely be leaking out the overflow and not the carburetor itself). As unlikely as it would be to have fuel flowing out the accelerator pump circuit and discharge port you would easily be able to identify such a leak by seeing it flow out of the accelerator pump discharge port in the front part of the carb throat. If the needle and seat are not sealing and fuel flow was available from the shut off valve as it should not be with no vacuum applied to it then it would not matter that the float level was set correctly because it would continue to flow past the needle ans seat when the float had risen to the proper shut off point. In this case it might leak out of the main discharge port before the level became high enough for it to leak out of the overflow or it might leak out both. It is doubtful that a defective enrichener would cause a leak because the fuel would have to rise to high to emerge from the enrichener discharge ports. It might leak out the off idle discharge ports but these are behind the venturi piston and the butterfly valve so you would have to raise the former and open the latter to see if fuel was emerging from these ports. I have not dealt much with H-D CV carbs but my understanding of them leads me to suggest the above. SO, a leaking carb with the engine shut off is most likely to be a result of a defective fuel tank valve so first remove the fuel hose from the shut off valve and see if there is fuel draining from the nipple at the valve or if you take it off at the carb if there is any fuel leaking out of the fuel line you removed from the carb.....There should be no fuel flow with the engine off and no vacuum. If there is no fuel flow here there should be no fuel flow from the carb unless the float level is out and the fuel level in the float bowl has risen too high before the fuel valve shut of fuel flow. Even so the fuel leak should not be continuous but only as much as there was fuel in the fuel line and carb downstream of the shut off valve. If the leak is continuous you know the valve is the first problem and then you also have a float level setting that is out allowing too much fuel into the float bowl and/or the needle and seat are not sealing and shutting off the flow when the float rises to the proper shut off height. Or, you could have a gasket leak at the float bowl. If there is no fuel flow from the fuel shut off valve and the float level is correct there likewise should be no flow from the accelerator pump (or any other circuit) because the fuel level would never be high enough to flow out the discharge the accelerator discharge or other ports. Remember that the accelerator pump check valve only operates when the fuel is being forced out of the accelerator pump circuit ie the valve does not stop or control fuel flow into the accelerator pump diaphragm area, it only stops flow back to the float bowl area when fuel is being pressurized to force fuel up and out the discharge port. I hope this helps somewhat in diagnosing your leak.
Nov 14, 2014 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Can I rebuild leaking fuel shut off valve
They do make rebuild kits for petcocks. Just going to depend on if they make one for your motorcycle or not. I did do a quick search for Harley petcock rebuild kits and they do make them.
Mar 23, 2014 | Harley Davidson Motorcycles
How do I resolve diagnostic code P0455 on my 2005 Chevrolet Tahoe?
Here is the definition and possible causes.
Possible causes - Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
P0455 CHEVROLET Description This diagnosis detects leaks in the Evaporative Emission System (EVAP) purge line using engine intake manifold vacuum. If pressure does not increase, the Engine Control Module (ECM) will check for leaks in the line between the fuel tank and EVAP canister purge volume control solenoid valve under the following vacuum test condition.
The vacuum cut valve bypass valve is opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP canister vent control valve will then be closed to shut the EVAP purge line off. The EVAP canister purge volume control solenoid valve is opened to depressurize the EVAP purge line using intake manifold vacuum. After this depressurization is implemented, the EVAP canister purge volume control solenoid valve will be closed.
Read more: http://engine-codes.com/p0455_chevrolet.html#ixzz24fVfq0Bx
Aug 26, 2012 | 2005 Chevrolet Tahoe
Kohler 20hp Craftsman mower started leaking fuel out of air filter and exhaust
i have been finding that the needle valve in the carb has not been seating from the newer fuel replace both the needle valve and the seat change the oil and you should be good to go i add a shut off valve to the ones i service and advise that the fuel be shut off when not in use and run the carb out of gas when not using for ever day
Jun 18, 2012 | Garden
Po 442 po 455
P0442 - Evaporative Emissions System Leak Detected (Small Leak)
P0455 - Evaporative Emissions System Leak Detected (Gross Leak)
This diagnosis detects leaks in the EVAP purge line using engine intake manifold vacuum. If pressure does not increase, the ECM will check for leaks in the line between the fuel tank and EVAP canister purge volume control solenoid valve under the following vacuum test condition. The vacuum cut valve bypass valve is opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP canister vent control valve will then be closed to shut the EVAP purge line off. The EVAP canister purge volume control solenoid valve is opened to depressurize the EVAP purge line using intake manifold vacuum. After this depressurization is implemented, the EVAP canister purge volume control solenoid valve will be closed.
Causes:
- Missing Fuel cap
- Incorrect fuel tank vacuum relief valve
- Leak is in line between intake manifold
Solutions:
- Re-tighten or replace fuel tank filler cap
- Replace damaged or leaking EVAP canister
- Replace damaged or leaking lines.
Feb 10, 2011 | Chrysler Town and Country Cars & Trucks
Codigo p1440
EVAP System Vent Circuit Malfunction
This diagnosis detects leaks in the Evaporative Emission (EVAP) purge line using of vapor pressure in the fuel tank. The EVAP canister vent control valve is closed to shut the EVAP purge line. The vacuum cut valve bypass valve will then be opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP control system pressure sensor can now monitor the pressure inside the fuel tank. If pressure increases, the Engine Control Module (ECM) will check for leaks in the line between the vacuum cut valve and EVAP canister purge volume control solenoid valve.
Possible causes
- Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve
- Foreign matter caught in EVAP canister vent control valve
- EVAP purge line (pipe and rubber tube) leaks
- EVAP purge line rubber tube bent
- Blocked or bent rubber tube to EVAP control system pressure sensor
- Loose or disconnected rubber tube
- EVAP canister vent control valve and the circuit
- O-ring of EVAP canister vent control valve is missing or damaged
- EVAP canister is saturated with water
- EVAP control system pressure sensor
- Absolute pressure sensor
Possible solution
- Loose fuel filler cap
- Leaking fuel filler cap
Hope helps (remember to rate this answer).
Jan 05, 2011 | 2000 Hyundai Sonata
Check engine light code PO442
You likely won't notice any drivability problems. P0442 indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter.
The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage.
Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
With a P0442, the most common repair is to Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back. Otherwise, replace the gas cap, or Inspect the EVAP system for cuts/holes in tubes/hoses.
Good luck and hope this helps
May 07, 2009 | 2001 Volvo S60
Garden Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
